Has anyone EVER managed to run: compressible steady state subsonic internal flow
Old   November 9, 2012, 09:08
Default Has anyone EVER managed to run: compressible steady state subsonic internal flow
Mihai Pruna
mihaipruna is on a distinguished road
If so, I would like to know which solver you used, and , if possible, see your input files...thanks!
mihaipruna is offline   Reply With Quote
Old   November 9, 2012, 09:39
treima is on a distinguished road
I´ve tried this with the solver "rhoCentralFoam".
At the inlet I took fixed Value for Temperature and velocity, at the outlet for pressure. I think my Mach number was 0.6. Steady state worked for simple geometries.
For which cases are you doing this?
regards
treima
treima is offline   Reply With Quote
Old   November 9, 2012, 11:23
Mihai Pruna
I'm trying to use rhoSimplecFoam for a duct with an inlet and an outlet.
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 04:59
Surface inejction- steady state - mass flow rate CFD-student FLUENT 0 January 25, 2012 13:40
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
buoyancy driven flow in steady state in CFX4.3 raymondyin CFX 11 May 7, 2001 06:15
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
