Rotor-stator case with non-overlapping zones
Old   November 16, 2012, 05:10
Default Rotor-stator case with non-overlapping zones
Anon
jrrygg is on a distinguished road
Hi all,
I am trying to run a case with a rotor-stator interface. I am using OpenFOAM 1.6-ext, and set up a case with cyclicGgi boundary conditions.
I tried to run it (with interDyMFoam), but it gives me the following error:
ubuntu@ubuntu:~/OpenFOAM/ubuntu-1.6-ext/run/MD5-OF-GGI-2$ interDyMFoam
| \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
Build  : 1.6-ext
Exec   : interDyMFoam
Date   : Nov 16 2012
Time   : 10:00:17
Host   : ubuntu
PID    : 5605
Case   : /home/ubuntu/OpenFOAM/ubuntu-1.6-ext/run/MD5-OF-GGI-2
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh mixerGgiFvMesh
void mixerGgiFvMesh::addZonesAndModifiers() : Zones and modifiers already present.  Skipping.
Mixer mesh:
    origin: (0 0 0)
    axis  : (0 1 0)
    rpm   : 13
Reading g
Reading field pd
Reading field alpha1
Reading field U
Initializing the GGI interpolator between master/shadow patches: statif/rotif
    From function void GGIInterpolation<MasterPatch, SlavePatch>::rescaleWeightingFactors() const
    in file /build/buildd/openfoam-1.6-ext-1.6.0/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/GGIInterpolationWeights.C at line 535
    Uncovered faces found.  On master: 981 on slave: 839
Reading transportProperties
Selecting incompressible transport model Newtonian
Killed
I have some zones that are not overlapping, as I have simplified my mesh to cover only 1/3 of 360 degrees. Is this what is causing it to crash? Does GGI support non-overlapping zones?
Picture of the setup:
jrrygg is offline   Reply With Quote
Skipping Zones 1337Hal FLUENT 1 June 27, 2022 09:33
merge zones Domi FLUENT 2 May 3, 2019 13:15
[Other] how to extract cell zones by cgnsToFoam Ohbuchi OpenFOAM Meshing & Mesh Conversion 0 July 22, 2010 04:19
Patch-Different values to different zones Pradeep FLUENT 0 April 26, 2005 08:50
surface-creation on 1 of 2 overlapping fluid zones Volker Pawlik FLUENT 0 November 17, 2000 05:15
