November 5, 2019, 23:55 |
Aerodynamic analysis of an aircraft fuselage
Suman Dathathreya
Rep Power: 7 |
I am currently performing a cfd simulation on openfoam to estimate the drag acting on the fuselage. The meshing of the fuselage is done on ansys meshing, cut-cell mesh with inflation is used and the y+ value is about 30, the turbulence model used is k-omega SST. On openfoam I am using the simplefoam solver. Kindly help me with setting up the case especially the fvschems and fvsolution, the case file is uploaded kindly suggest me on the correct steps as I am trying such kind of simulation on Openfoam for the first time. Thank you in advance. fvSolution.txt fvSchemes.txt nut.txt k.txt omega.txt |
Analysis of a Model Aircraft | GusRus | FLUENT | 0 | February 17, 2015 10:38 |
table fan aerodynamic analysis using gambit and fluent | ziq | FLUENT | 24 | February 20, 2011 07:31 |
Aerodynamic noise analysis with CFX | famarcfd | Main CFD Forum | 0 | December 14, 2010 07:53 |
Aerodynamic noise analysis with CFX | famarcfd | ANSYS | 0 | December 13, 2010 06:27 |
Aerodynamic Analysis | Simulationengineer | CFX | 3 | October 5, 2010 20:15 |
