called for invalid fileName newfile
Old   November 19, 2012, 06:18
Default called for invalid fileName newfile
hewei is on a distinguished road
HI all,
I copied the case and data together into another computer, the same system and same version of OF, but when I run the case, it displays like this
fileName::stripInvalid() called for invalid fileName newfile
For debug level (= 2) > 1 this is considered fatal
Aborted
http://www.cfd-online.com/Forums/ope...mandtouse.html here Mark said change some file's name without space, I really dont understand which file's name I should modified. can somebody help me?
thank you!
w.
hewei is offline   Reply With Quote
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse adona058 OpenFOAM Bugs 34 December 8, 2022 21:27
Motorcycle CFD champion STAR-CCM+ 7 November 7, 2017 10:00
Error during surface Remesher miharbi STAR-CCM+ 3 May 25, 2012 08:29
understanding how turbulence models are called romant OpenFOAM Programming & Development 0 March 21, 2012 09:22
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 05:49
