Non-physical flow: omega is fixed at inlet
Old   November 15, 2012, 11:18
Default Non-physical flow: omega is fixed at inlet
Abdulhaq
aljazari is on a distinguished road
Hi
This is driving me crazy!
I'm simulating a flow past a transonic aerofoil (RAE 2822), I wrote a small script to generate a blockMeshDict which would then generate a C-Mesh around the aerofoil. Everything except omega at the inlet is fine.
Here's my part of my entry for omega:
internalField   uniform 242315;
boundaryField
    INLET
        type            fixedValue;
        value           $internalField;
This is supposed to be an initial value, the thing is; omega stays as it is told: fixed at the inlet. Here's screenshot:
Something even more strange: I have a c-mesh for this same aerofoil converted from Fluent (originally from Numeca), and when I run the simulation using this mesh with the exact same conditions, omega is changing at the inlet, i.e. it is being solved!. Here's a screenshot:
This seems more 'physical'.
Am I correct to say the 1st screenshot doesn't look correct at all. If yes, what is wrong with the mesh/boundaries. Can someone help me?
I have also uploaded the two cases, the first one is using the mesh I generated, (blockMeshDict) is included as well. The second is using the converted Fluent mesh.
*I originally had the two meshes to have the same boundaries but then I decided to create a 'topAndBottom' boundary patch as well in the hope that it will change the behaviour of omega at the inlet.
Case1(block Mesh): http://www.mediafire.com/?bfemuyx2qofh4qh
Case2(fluent mesh): http://www.mediafire.com/?zvz2n15izzb0i1m
aljazari is offline   Reply With Quote
omega, rhocentralfoam
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 18:42
mass flow inlet Mech FLUENT 2 July 7, 2006 07:37
modelling slug flow with pressure inlet Azman FLUENT 0 May 29, 2006 06:45
