-   -   ICEM and MRFzones (http://www.cfd-online.com/Forums/openfoam-solving/109664-icem-mrfzones.html)
sharonyue November 23, 2012 04:08
ICEM and MRFzones
Hi Foamers:
http://openfoamwiki.net/index.php/MRFSimpleFoam this is a tutorial of MRF and gambit.
But ICEM is different with GAMBIT, is there any tutorial of ICEM? I am confused of setting MRFzones..
Aadhavan November 24, 2012 07:15
Please explain more about your problem, what you want to do? where you are getting doubt? what are the boundary condition you want to use?
create you geometry and give the BC according to your need and ICEM.
for your rotating region give wall BC the export the mesh in to .msh format
then export OF using fluent3DMeshToFoam
to create sets just follow the below link
http://www.cfd-online.com/Forums/ope...mesh-foam.html
Thanks,
Aadhavan
sharonyue November 24, 2012 08:12
1 Attachment(s)
Originally Posted by Aadhavan (Post 393944)
Thanks,
Aadhavan
Thanks Aadhavan, What confused me is I didn't know how to set BC in ICEM.because in other cases I just set the BC in openfoam, I only set the PARTS in ICEM such as outlet, inlet, walls, but someone said if u wanna use MRF,u have to set BC in ICEM,so I don't know what to do in the next step. BTW, I have tried without setting BC in ICEM, but after fluentMeshToFoam, there is nothing in the cellZones dictionary .
the image I attack below. the outter cylinder is wall, the inner cylinder is rotating zone, and I want the cube to rotate.
Aadhavan November 24, 2012 12:32
The wiki MRFSimpleFoam, is the only tutorial similar to your problem.
I dont know ICEM so I can not give you any idea in that regards.
I am using Gambit, I didnt give mfr zone in gamit. I have defined only periodic condition , inlet, outlet and wall after that, I have used createPatch and topoSet (to specify the rotating zone). I hope you can also follow this way.
the usage of topoSet and createPatch, go through the link in the previous post.
thanks,
Aadhavan
sharonyue November 29, 2012 21:58
anyone can give me an instruction of this?now it is still unsettled
sharonyue December 1, 2012 04:56
Hi guys, I have handled this, maybe it can be call MRF via ICEM, but its a little complex to write here, if somebody want to know just text me.
