-   OpenFOAM Running, Solving & CFD (
-   -   inletvalue and value in inletoutlet BC (
immortality November 23, 2012 06:50
what are inletvalue and value must be assigned for inletoutlet or outletinlet BCs?if inletvalue is velocity whats value?
chegdan November 23, 2012 07:48
value is just a default value that will be changed at runtime and calculated.
inletValue is the value of the velocity when the flux is negative at the outlet, i.e. inflow.
immortality November 23, 2012 09:15
then value isn't important and relates to inner calculations of openfoam?could it be set as (0 0 0) for convenience?
chegdan November 23, 2012 09:55
yes, you can set it to
value uniform (0 0 0);
for examples, you can search in the tutorials directory with
grep -R "inletOutlet" .
immortality November 23, 2012 18:18
thank you dan.whats about calculated BC?as instance density in perfect gas solutions can be set as calculated?if we dont set it so how can we draw its field with paraview after solve?
And If we determine a value in this kind of BC it has any effect?
Thank you again so much.
