Home > Forums > OpenFOAM Running, Solving & CFD
realizing pressure based and density based solvers
Old   November 23, 2012, 16:10
Default realizing pressure based and density based solvers
immortality's Avatar
Ehsan
immortality is on a distinguished road
hello
How can perceive a solver is pressure based type or density based one?
Each of these are more appropriate for what kind of flows?
Thanks
immortality is offline   Reply With Quote
Old   June 16, 2013, 12:07
Ehsan
Hi
I answer to my thread after a while has passed briefly.
AFAIK till now rhoCentralFoam is the only density-based solver.
in density based solvers in the code (.C) of them,continuity equation is solved for obtaining rho at first and there isn't an equation mixing continuity and momentum equations to obtain a pressure corrector equation.
density based solvers are more appropriate for high velocity flows and for shock and expansion fan capturing too,also pressure based ones has modified to work in high flow velocities and shock capturing with high resolution better than before but still density based solvers are better for around sonic and supersonic or moving shock waves.
one point:rhoCentralFoam is an explicit solver though for good results maxCo should be lower than .4-.5.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
Thread Tools
Trackbacks are On
Using Density Gradient C_R_G(c,t), Pressure Based Solver Anirudh_Deodhar Fluent UDF and Scheme Programming 1 October 25, 2013 05:43
Pressure vs. Density based jan FLUENT 2 May 3, 2007 03:45
Pressure based and Density based Solver Xobile CD-adapco 1 November 30, 2004 22:13
pressure and density based solvers sun Main CFD Forum 0 November 8, 2004 07:20
Pressure vs Density based CFD solvers Danie Main CFD Forum 0 October 5, 2004 09:48
