density based solvers
Old   November 24, 2012, 15:46
Default density based solvers
immortality's Avatar
Ehsan
immortality is on a distinguished road
in my thesis there are velocities around 300 when sound speed is 600 and also there are moving shocks like shock tube.Im confused what solver should I use.until now I thought rhopimplefoam is suitable but now I read some about type of solvers.It was be written that they both now can be used for incomp and comp flows.but im unsure.
immortality is offline   Reply With Quote
Old   November 26, 2012, 02:17
treima is on a distinguished road
which kind of equation describes your flow? Euler, Navier-Stokes or anything else?
But like you suggested in your other thread, rhoCentralFoam can be a good choice. Perhaps have a look into the source-code of the solvers and the tutorials, which one might fit to your case. Normaly there is a small description of the properties of the solver. Or have a look into the OpenFOAM wiki or this forum.
regards
treima
treima is offline   Reply With Quote
[ICEM] Geometric density sources in ICEM rana41671 ANSYS Meshing & Geometry 2 June 14, 2018 05:44
Variable Density Function ryzd FLUENT 1 August 25, 2011 14:16
pressure correction scheme vs density based scheme PCFD Main CFD Forum 0 May 18, 2009 15:57
Pressure based and density based lgriffiths OpenFOAM Running, Solving & CFD 0 March 4, 2008 10:59
Density based codes? H.S.Muralidhara Main CFD Forum 3 May 28, 1999 06:29
