Home > Forums > OpenFOAM Running, Solving & CFD
Problem with very high gradients
Old   November 27, 2012, 14:12
Default Problem with very high gradients
Henning86 is on a distinguished road
Hi Foamers,
i'm trying to implent a new boundary condition for which i need the second derivative of U in normal direction. (slip velocity)
In order to get a second order derivative (which isn't laplacian) i'll do:
    volScalarField Ux(U.component(0));
    dU=fvc::grad(Ux);//VolVectorField
    partial2UT=fvc::grad(dU);//VoltensorField
in partial2UT only components 0,4,8 are of interest i store these values in another tensorfield and repeat it for Uy and Uz so that i finally get.
| Ux,xx Uy,xx Uz,xx |
d2U=| Ux,yy Uy,yy Uz,yy |
| Ux,xx Uy,xx Uz,zz |
This works great but only to a certain dimension of the mesh. Attached to this post there are 2 cases and a modified rhoPimpleFoam solver.
the first case "microKanal2"(Kanal:channel in german) has a height of 1.68e-3 meters. The velocity field result in a parabola with an increasing maximum for higher x values. Therefore the first derivative dU shows in y direction a linear function. The tensor compoent(3) Ux,yy should be a a constant value for a cross section of the channel, but changing with the position of x (see picture).
the second case "microKanal" has a height of 1.68e-4 meters. For component 3 of the tensor there are following values (see attached picture)
The field isn't smooth at all it suddenly jumps to another value. A possible reason for that could be that double isn't accurate enough.
Does anyone know what the problem is and how it can be solved?
Best regards
Henning
http://dl.dropbox.com/u/9273087/microKanal2.tar.gz
http://dl.dropbox.com/u/9273087/microKanal.tar.gz
http://dl.dropbox.com/u/9273087/rhoPimpleFoam.tar.gz
Henning86 is offline   Reply With Quote
Old   November 28, 2012, 17:23
immortality's Avatar
Ehsan
immortality is on a distinguished road
hello
Where did you write these codes?
immortality is offline   Reply With Quote
Old   November 29, 2012, 18:05
the code is in the rhoPimpleFoam.C after the pimple loop
or what do you mean exactly?
Old   February 13, 2013, 16:22
Mieszko Młody
ziemowitzima is on a distinguished road
Hello Henning
I am facing the same problem.
I need to calculate second derivative e.g for field F i need F_xx, F_yy.
I did it the same way as you.
gradF = fvc::grad(F) // vector of first derivatives
gradgradF = fvc::grad(gradF) // tensor of second derivatives
as far as gradF is fine/smooth, gradgradF is not anymore ...
Were you able to solve this problem ?
Best
ZMM
ziemowitzima is offline   Reply With Quote
Old   February 15, 2013, 18:27
sadly not.
for what do you need it?
Old   February 15, 2013, 18:40
Mieszko Młody
Dear Henning,
please see my post located at:
how to calculate mixed derivative
where I am writing about other way of dealing with second order mixed derivative.
What do you think about that ?
Best
ZMM
Thread Tools
Trackbacks are On
rhoCentralFoam - Problem high difference pressure Nicolas_OF OpenFOAM Running, Solving & CFD 0 June 11, 2012 09:29
Combustion problem, Temp to high. Devin FLUENT 6 April 26, 2012 05:46
Problem about 3D blunt body high Re simulation David FLUENT 0 September 27, 2002 10:59
High temperature problem Julie Polyakh CD-adapco 1 January 5, 2002 17:24
Problems of numerical instability because of high gradients Xiangyang Ye Main CFD Forum 4 September 28, 1998 03:48
