BC: inletOutlet,buoyantpressure,and $interFields
Old   November 27, 2012, 20:49
Default BC: inletOutlet,buoyantpressure,and $interFields
Dongyue Li
sharonyue is on a distinguished road
hi Foarmers:
I have been learning using OF for 3 months,now I am facing some tiny difficulties about BC.
I see in alpha1 dictionary, you can set
OUTLET
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
I interpret it as air can get in and get out, but while simulating , I find it water can get out too, so what does this mean?
in p_rgh dictionary,
walls
        type            buoyantPressure;
	value		uniform 0;
I dont get this buoyantPressure , ,,,some other cases set:
walls
        type            fixedFluxPressure;
        value           uniform 0;
what does this fixedFlusPressure mean and the difference between buoyantpressure?
also in p_rgh dictionary
outlet
	type		fixedValue;
	value           $internalField;
Does this $internalField mean it is calculated by the internaFields? can I just modify it to
atmosphere
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
and the k and epsilon dictionary, I know k can be caculated by 1/2*(u^2)....,but some time it cant be set this way, so I dont know how to set the value of them.....
your help is very appreciated.Thank you in advance.
sharonyue is offline   Reply With Quote
Old   November 29, 2012, 02:04
Dongyue Li
can anyone give me a hint?
Old   December 27, 2012, 06:41
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
please check this thread,
http://www.cfd-online.com/Forums/ope...onditions.html
regards,
Ahmed Khattab is offline   Reply With Quote
Old   July 18, 2013, 06:51
Default hi you offer the site that look like not very helpful
jiujiumin
jiujiumin is on a distinguished road
Originally Posted by rebel ahmed View Post
regards,
hi you offer the site that look like not very helpful, i want to know the diference between buoyantpressure and fixedfluxpressure.
jiujiumin is offline   Reply With Quote
Old   August 26, 2013, 19:54
Default buoyantpressure vs fixedfluxpressure
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
Anyone knows the answer to the question in this thread?
I have a buoyantBoussinesqPimpleFoam that crashes if I use buoyantpressure , but converges perfectly if I use fixedfluxpressure. I've seen both BCs used in p_rgh. Anybody care to comment? Thanks
JR22 is offline   Reply With Quote
Old   August 26, 2013, 19:59
Dongyue Li
Sorry, I still dont know the difference between buoyantpressure and fixedfluxpressure.
Old   May 28, 2014, 08:02
Srivathsan N
Sherlock_1812 is on a distinguished road
Any clarity on the difference between them yet, sharonyue?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   October 16, 2014, 03:25
Dongyue Li
Hello!
Now I know that the difference between outletInlet and inletOutlet,
outletInlet:
outlet is a fixed value and inlet is zerogradient. Thats means if you set outlet value to be 0, so only 0alpha phase can get out. but any phase can get in.
inletOutlet:
vice versa.
Now I still dont know the difference between buoyantPressure and fixedFluxpressure. But looks like the first one is always used in VOF but the second one is used in two-fluid model. Im not sure.
Any comments is welcomed.
Old   October 18, 2014, 17:06
Retired Super Moderator
Bruno Santos
Quick answer - Have a look at this thread: http://www.cfd-online.com/Forums/ope...xpressure.html
