-   -   multiphaseEulerFoam loosing fluid with zeroGradient for p on walls??? (http://www.cfd-online.com/Forums/openfoam-solving/109852-multiphaseeulerfoam-loosing-fluid-zerogradient-p-walls.html)
petr.f. November 28, 2012 07:33
1 Attachment(s)
Dear fellow foamers,
I've run into another strange problem with multiphaseEulerFoam (mpEF). In order to perform scalability tests with mpEF, I've prepared a simple 3d dam break case (only 2 phases - air and water). I've used standard boundary conditions and solver settings taken from tutorial files (see below). When I use the zeroGradient BC for pressure on solid walls all the water somehow leaks through the walls (with no effect on Courant number!). fixedFluxPressure works just well... Any idea where this behaviour comes from?
0.org/alphaair
boundaryField
walls
type zeroGradient;
atmosphere
type inletOutlet;
phi phiair;
inletValue uniform 1;
value uniform 1;
alphawater is almost the same, only on atmosphere the inletValue and value are uniform 0
0.org/p
boundaryField
walls
type zeroGradient;
atmosphere
type totalPressure;
p0 uniform 0;
U Uair;
phi phiair;
rho rho;
psi none;
gamma 1;
value uniform 0;
0.0rg/Uair
boundaryField
walls
type fixedValue;
value uniform (0 0 0);
atmosphere
type fluxCorrectedVelocity;
... again, Uwater is the same
system/fvSolution
solvers
p
solver GAMG;
tolerance 1e-7;
relTol 0.05;
smoother DIC;//GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
cacheAgglomeration on;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
pFinal
solver PCG;
preconditioner
preconditioner GAMG;
tolerance 1e-7;
relTol 0;
nVcycles 2;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
mergeLevels 1;
tolerance 1e-7;
relTol 0;
maxIter 20;
pcorr
$pFinal;
tolerance 1e-5;
relTol 0;
U
solver smoothSolver;
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
UFinal
$U;
tolerance 1e-7;
relTol 0;
PIMPLE
// nOuterCorrectors 1;
nCorrectors 3;
nNonOrthogonalCorrectors 0;
nAlphaSubCycles 3;
relaxationFactors
"U.*" 1;
p 1;
As for fvSchemes, I use vanLeer and limitedLinear as in damBreak tutorial.
Thanks, Petr.
