Having problem in airfoil calculation
Old   November 28, 2012, 20:32
Default Having problem in airfoil calculation
Zifei Yin
yzf1215 is on a distinguished road
I'm using rhoSimpleFoam to calculate flow over airfoil. And after several iterations the Ux seem to be zero in the inlet. Also the temperature have some problems.
This is my case
http://pan.baidu.com/share/link?shar...&uk=2234161950
And the mesh
Also, the checkMesh
Checking geometry...
Overall domain bounding box (-14.9978 -15 -0.424248) (15 15 0.424248)
Mesh (non-empty, non-wedge) directions (1 1 0)
Mesh (non-empty) directions (1 1 0)
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (3.30002e-18 -1.7807e-18 -1.66129e-18) OK.
Max cell openness = 1.08077e-14 OK.
Max aspect ratio = 595.261 OK.
Minumum face area = 7.97538e-09. Maximum face area = 1.29329. Face area magnitudes OK.
Min volume = 6.76708e-09. Max volume = 0.341398. Total volume = 681.489. Cell volumes OK.
Mesh non-orthogonality Max: 80.4107 average: 22.3043
*Number of severely non-orthogonal faces: 26.
Non-orthogonality check OK.
<<Writing 26 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.864702 OK.
Mesh OK.
End
What fvScheme will you suggest?
Last edited by yzf1215; November 28, 2012 at 20:57. Reason: Adding information of checkMesh
yzf1215 is offline   Reply With Quote
Old   November 29, 2012, 02:36
Simone
batta31 is on a distinguished road
Hi!
First of all I'll try to correct the error that checkMesh gives to you
I don't know if that's the problem but it will be better if you don't have that failure.
Greetings
Simone
batta31 is offline   Reply With Quote
Old   November 29, 2012, 02:43
Zifei Yin
I have tried this way, eliminated the non-otrhogonal mesh, but the calculation still blows up.
Lift Hysteresis problem in Oscillating Airfoil Farid CFX 3 March 29, 2012 05:52
Problem Meshing Airfoil erodv OpenFOAM 12 January 11, 2012 17:46
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Mesh problem sloted airfoil Alejandro88 Main CFD Forum 0 April 20, 2011 21:06
Problem with drag coefficient calculation Crystal FLUENT 2 June 18, 2009 05:44
