Home > Forums > OpenFOAM Running, Solving & CFD
Problem in solving
Old   December 3, 2012, 09:19
Default Problem in solving
immortality's Avatar
Ehsan
immortality is on a distinguished road
this error tells the maximum number of iterations the solver is reached probably in e equation solving.why this is occuring?
Im engaged in this problem but it don't want to be resolved!
fluxScheme: Kurganov
Starting time loop
Mean and max Courant Numbers = 0.10019 0.211345
Time = 1e-09
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
swak4Foam: Allocating new repository for sampledGlobalVariables
smoothSolver: Solving for Ux, Initial residual = 0.878819, Final residual = 9.93747e-10, No Iterations 438
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 9.87651e-10, No Iterations 693
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for e, Initial residual = 0.94115, Final residual = 5.58403e-06, No Iterations 1002
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 69.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::specieThermo<Foam::hConstThermo<Foam:erfec tGas> >::T(double, double, double (Foam::specieThermo<Foam::hConstThermo<Foam:erfe ctGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam:erfe ctGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam:erfe ctGas> >::*)(double) const) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#3 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted
immortality is offline   Reply With Quote
Old   January 29, 2013, 02:10
Anant Diwakar
diwakaranant is on a distinguished road
Hi
I am also having the same problem.
Did you find the cause of its occurrence ?
Thanks
Anant
diwakaranant is offline   Reply With Quote
Old   January 29, 2013, 10:51
Ehsan
hi dear Anant.I did some changes in fvSchemes and fvSolutions.using CrankNicholson .5;and div(phi,U) Gauss upwind; is better than Euler and linear respectively.
a very important thing is boundary conditions and initial conditions.I changed initial condition and increased it because it had made a supersonic flow at inlet but it must be subsonic in my problem.
and also try another solver and change maxIter for e in specieThermo.c (I think it was there) can lead to more stability.
whats the problem you want to model?comp or incomp?
Old   January 30, 2013, 01:45
Anant Diwakar
Dear Ehsan
Thanks a lot for your help. I tweaked the initial conditions and it's
working now.
I am solving compressible flow between rotating cylinders using rhoCentralFoam.
Regards
Anant
Old   January 30, 2013, 05:57
Ehsan
Dear Anant
Im working with rhoCentralFoam and rhoPimpleFoam.
Im interested in the problem you are working on.could you send me your case please?
Thanks.
Thread Tools
Trackbacks are On
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Problem with SimpleFoam for a solution around an OneraM6 wing gara1988 OpenFOAM Running, Solving & CFD 3 November 13, 2012 06:47
AMI speed performance danny123 OpenFOAM 19 October 24, 2012 07:44
