-   -   what this error comes from? (http://www.cfd-online.com/Forums/openfoam-solving/110152-what-error-comes.html)
immortality December 4, 2012 18:17
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::ePsiThermo<Foam::pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::ePsiThermo<Foam::pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::ePsiThermo(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::ePsiThermo<Foam::pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception
immortality December 5, 2012 03:08
I use a 64-bit version on a system by 2Gb Ram.could the problem arises from this point?or what?
Hanzo December 5, 2012 04:24
I would check the source code for
There could be the chance that you somehow divide by a zero value like division by zero density or similar. I once had that case.
immortality December 5, 2012 06:40
may be this is because of initial condition.I put pressure and temperature zero due to empty channel that should become full.is it incorrect?
immortality December 5, 2012 08:26
for instance see this time step:
Mean and max Courant Numbers = 0.140537 0.296461
deltaT = 1.31579e-07
Time = 4.86842e-06
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Ux, Initial residual = 1.13168e-05, Final residual = 2.04904e-17, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 0.00894171, Final residual = 1.97135e-17, No Iterations 3
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for e, Initial residual = 1.43136e-05, Final residual = 1.55745e-10, No Iterations 201
smoothSolver: Solving for omega, Initial residual = 0.000587127, Final residual = 1.92363e-11, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.00730572, Final residual = 1.34671e-10, No Iterations 2
ExecutionTime = 38.88 s ClockTime = 58 s
Hanzo December 5, 2012 23:07
Maybe you should post an overview what you are doing. Setting Temperature to zero may cause your error. I am not sure if there is a valid setting for such an initial condition.
Try to check the
calculate()
method if your error still occurs.
immortality December 22, 2012 11:57
thanks.how shuld I use calculate method?
Hanzo December 24, 2012 01:53
Did you try to find the source code of
Originally Posted by Hanzo (Post 395858)
