mpirun error(signall 9(killed))
hi
I run my case in parallel with dsmc on the notebook It's work but when I run on my pc , see this error: I am appreciate for any help. \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : dsmcInitialise -parallel Date : Dec 26 2012 Time : 11:40:09 Host : "172-15-2-166" PID : 4427 Case : /home/moosaie/OpenFOAM/moosaie-2.1.1/run/tutorials/discreteMethods/dsmcFoam/hemispherical nProcs : 4 Slaves : 3 ( "172-15-2-166.4428" "172-15-2-166.4429" "172-15-2-166.4430" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Initialising dsmc for Time = 0 Constructing constant properties for Air Initialising particles -------------------------------------------------------------------------- mpirun noticed that process rank 2 with PID 4429 on node 172-15-2-166 exited on signal 9 (Killed). -------------------------------------------------------------------------- |
this the log.dsmcfoam file:
nobody can help me!!!???
"If your job received a KILL signal (#9), it probably comes from the batch system on these machines. Your job needed more resources than what you asked for, or more than is available on the machine (memory,..."
http://forum.abinit.org/viewtopic.php?f=14&t=95 |
sorry wrong post
