how to run the propeller Tutrial
the example of propeller has the below error when i use pimpleDymFoam:
thesis@thesis-X58A-UD7:~/Desktop/opt/openfoam210/tutorials/incompressible/pimpleDyMFoam/propeller$ pimpleDyMFoamthanks. |
Have you tried executing the "Allrun" script?
- Niels |
hi niels
I did that now.this appears and cursor is shown: Code:
thesis@thesis-X58A-UD7:~/Desktop/opt/openfoam210/tutorials/incompressible/pimpleDyMFoam/propeller$ ./Allrun |
I looks correct to me. You can always check the log-files, which are being generated or see if data is outputted.
- Niels |
nothing of results are shown on the command shell.is it true?all is done at the background?what commands can i use manually?
Thanks. |
Yes, everything is put into log files. If you want, you can do all the steps in the Allrun manually.
/ Niels |
question
how can i implement a new propeller geometery into the pimpleDymfoam solver? fluentMeshToFoam is ok?what can i do for boundarycondition of (*propeller)? |
| All times are GMT -4. The time now is 04:31. |
