January 9, 2013, 13:51 |
error by make simple changes in fvSchemes
Ehsan
Rep Power: 26 |
I just changed expressions in gradSchemes from linear to upwind and an error showed!why?!
[CODEddtSchemes { default Euler; } gradSchemes { default Gauss upwind; grad(p) Gauss upwind; } divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phid,p) Gauss limitedLinear 1; div(phi,K) Gauss linear; div(phi,h) Gauss limitedLinear 1; div(phi,k) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(phi,R) Gauss limitedLinear 1; div(phi,omega) Gauss limitedLinear 1; div((rho*R)) Gauss linear; div(R) Gauss linear; div(U) Gauss linear; div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default none; laplacian(muEff,U) Gauss linear corrected; laplacian(mut,U) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; laplacian(DomegaEff,omega) Gauss linear corrected; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(alphaEff,h) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; }][/CODE] Code:
Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model kOmegaSST --> FOAM FATAL IO ERROR: attempt to read beyond EOF file: /home/thesis/Desktop/WR_Pimple/system/fvSchemes::gradSchemes::default at line 25. From function ITstream::read(token&) in file db/IOstreams/Tstreams/ITstream.C at line 83. FOAM exiting |
Display Modes | |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
[ICEM] Using a hybrid mesh for a simple pipe | Udio_NT | ANSYS Meshing & Geometry | 17 | October 18, 2012 15:42 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
[Q]How to make MPEGs with CFD datas??? | Bum-Seok Hyun | Main CFD Forum | 4 | February 16, 2000 19:59 |
SIMPLE algorithm | Jonathan Castro | Main CFD Forum | 3 | December 10, 1999 05:59 |
