Home > Forums > OpenFOAM Running, Solving & CFD
Calculate interface curvature in interFoam
Old   January 11, 2013, 15:26
Default Calculate interface curvature in interFoam
styleworker is on a distinguished road
Hi there,
actually I'm solving two phase flows with MRFInterFoam (OF 2.1.1) in a single rotating cylinder, which is half filled with a fluid.
I would like to calculate the resulting capillary pressure, which is connected with the interface curvature. Andrea allready wrote a script for calculating the curvature, but it seems not to work.
Does anybody have a idea?
styleworker is offline   Reply With Quote
Old   January 15, 2013, 14:03
I've found that, if I add the following code to controlDict, I can extract the curvature to vtk and ascii format for a defined patch. So I can extract the coordinates in x and y.
If cyclic boundaries are involved, isoSurface has to be changed to isoSurfaceCell, but it isn't possible anymore to extract the surface for a defined patch.
But it is still possible to add a contour filter (alpha=0.5) and slice filter to the model in paraView. The coordinates can easily exported as *.csv.
HTML Code:
functions
    elevationVTK
        type            surfaces;
        functionObjectLibs
            "libsampling.so"
        outputControl   outputTime;
        surfaceFormat   vtk;
        interpolationScheme cellPoint;
        fields
            alpha1
        surfaces
            topFreeSurface
                type        isoSurface;
                isoField    alpha1;
                isoValue    0.5;
                interpolate true;
                exposedPatchName nameOfPatch;
    elevationRAW
        type            surfaces;
        functionObjectLibs
            "libsampling.so"
        surfaceFormat   raw;
        fields
            alpha1
        surfaces
            topFreeSurface
                type        isoSurface;
                isoField    alpha1;
                isoValue    0.5;
                interpolate true;
Thread Tools
Trackbacks are On
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 11 January 5, 2013 07:21
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
sharp interface and curvature yukn Main CFD Forum 0 October 12, 2011 12:54
Interface location problem in interFoam cfd_user2011 OpenFOAM 1 July 7, 2011 12:04
InterFoam - Measuring distance of interface from a precribed point/patch Ak_cfd OpenFOAM 0 May 27, 2010 18:41
