Home > Forums > OpenFOAM Running, Solving & CFD
Parallel processing warning
Old   January 16, 2013, 07:57
Default Parallel processing warning
Aathavan
Aadhavan is on a distinguished road
Hi there,
I am trying to run my case in high performance machine with 120 processors.
the same case is running in machine without any problem with 4 processors.
I am using MRFSimpleFoam,
While running the case in HPC with 120 processor I am getting the error as follows:
No field sources present
--> FOAM Warning :
From function MRFZones(const fvMesh&)
in file cfdTools/general/MRF/MRFZones.C at line 65
The MRFZones are not run time modifiable
using 'timeStampMaster' or 'inotifyMaster'
for the entry fileModificationChecking
in the etc/controlDict.
Use 'timeStamp' instead.
after this warning the calculation is going on.
Do I need to worry about it? can anybody give me some idea??
Thanks for your time and help,
Aadhavan
Aadhavan is offline   Reply With Quote
Old   April 18, 2013, 15:01
Dogan
dogan is on a distinguished road
i received the same error message while running my case in 8 processors with MRFSimpleFoam. Did you get an answer for your problem?
thanks
Dogan
dogan is offline   Reply With Quote
Old   April 22, 2013, 03:09
Aathavan
I didnt notice any problem in the results, however you can fix that warning message following the given instruction in the warning message.
in the etc/controlDict. // this is the file one you need to edit
Thanks,
Aadhavan
Thread Tools
Trackbacks are On
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 111 April 5, 2016 21:28
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
