DieselEngineFoam heat release
I am attempting to extract dQ from my simulation using simplefunctionobjects and swak4foam. I successfully implemented the following in OF2.1.x: functions ( volumeAverage { type volumeAverage; functionObjectLibs ( "libsimpleFunctionObjects.so" ); verbose true; fields ( T dQ C7H16 ); factor 1; } ); Unfortunately due to other problems I am now using OF1.7.1 . When I add this function to the controlDict in OF1.7.1 the Temperature and C7H16 fields are successfully extracted, however I recieve the following error for dQ. FOAM Warning : From function probes::read() in file volume/volumeFieldFunctionObject/volumeFieldFunctionObject.C at line 91 Unknown field dQ when reading dictionary "::volumeAverage" Can only probe registered volScalar, volVector, volSphericalTensor, volSymmTensor and volTensor fields Which from what I can understand, means that it cannot read/recognize dQ. Has anyone experienced this before? and does anyone know another method of extracting dQ. I have tried execFlowfuntionobjects but my thermomodel is not supported. Many Thanks, ris |
I have another question regarding extracting the liquid penetration length from the data set during runtime. Looking in spraycloud.H , I can see there is a liquidPenetration function however I am not too familiar with c++ and have trouble in trying to output this value. Please could some point me in the direction of outputting this value to a log file during runtime or a similar output to what is present in OF2.1.x. Many Thanks, ris. |
dQ is not a registered field as it is only output as needed from the chemistry model (chemistry.dQ()). You would need to create a field registered with the object (say Dq) and update is every iteration with the chemistry (Dq = chemsitry.dQ()).
Have a look at the createFields.H for reactingParcelFoam (which is also used with sprayFoam) to see how to create a registered field. As for penetration length, have a look at this post: http://www.cfd-online.com/Forums/ope...netration.html Its slightly different in 2.1.x, but there are still member functions for penetration that you could use (search through the code documentation here: http://www.openfoam.org/docs/cpp/). This would require you to modify the code, and I would recommend creating a new solver so as not to break the stock one. |
Thanks for the quick response, I will attempt to get something working soon.
