-   -   OF 1.6 extend. GGI - rotation around two axis - C++ newbie needs help (http://www.cfd-online.com/Forums/openfoam-solving/112040-1-6-extend-ggi-rotation-around-two-axis-c-newbie-needs-help.html)
A.Wendy January 21, 2013 02:51
2 Attachment(s)
Hi everybody,
i have a problem and i hope you can help me.
i am planing to simulate an gyro-copter including the auto rotation.
i was able to implement some rigid body movement into the mixerggi library and can simulate a rotation around one fixed axis. but i also want to simulate the flapping hinge. for that i need to make a rotation around a second axis.
i know what i have to implement but i dont know how.
the plan is the following:
reading out he forces using forces library <- works
recalculate an ne rpm for rotation <- works
rotate the rotor around z-axis <- works
change the rotation axis for flapping hinge <- does not work (see below)
rotate rotor for flapping hinge <- should work
change rotation axis back to z-axis and start to next time step.
here to the problem with the rotation for the flapping hinge:
when the rotor is rotating around the z-axis the coordinate system for the flapping hinge will change by each time step. so i have to compute this axis manually. i think i can do this. but i can not store these data in the variable of the mixerGgi script.
the variables (classes) are:
csPtr_().axis()
csPtr_().origin()
i am able to change the origin but not the axis. has anyone an idea to solve this problem?
here is the declaration:
//- Return coordinate system
const coordinateSystem& cs() const
return csPtr_();
how can i change it? why can i change the origin but not the axis? both have the same declaration or?
i added the c-file and header.
Best wishes
Andreas
A.Wendy February 4, 2013 09:05
push...
nobody got an idea?
