[swak4Foam] can i change BC from wall to patch in groovyBC? |
January 22, 2013, 01:11 |
Ehsan
Rep Power: 26 |
groovyBC can set a variable BC.but can i change type of BC by it at specified time domains?
January 22, 2013, 11:39 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Switching form Dirichlet (fixedValue) to Neuman (fixedGradient): yes
January 22, 2013, 12:03 |
Ehsan
Rep Power: 26 |
yes.i supposed patch in blockMeshDict for both of patch and wall in my groovyBC condition.is it possible that this is the source of printStack error when the boundary should be wall at groovyBC?
clearly questioning does "wall boundary" is set by only (U=U of wall,T:zeroGradient,p:zeroGradient)? do these conditions give the patch impermeable property like a wall(suppose fluid laminar for not confusing with wallFunctions? thanks. |
January 23, 2013, 08:40 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
For most practical purposes patch and wall behave the same. Only certain BCs/models (turbulence, radiation, heat transfer) behave differently on them
January 23, 2013, 09:34 |
Ehsan
Rep Power: 26 |
thanks.yes Im searching to find the cause of the error OpenFOAM gives.
I had a thread without answer although is irrelevant but i submit it here hoping to get an answer.why in "hConstThrmo" and "specieThermo" two different dimensions for Cp are commented?(J/kmol.K and J/kg.K) could you enlighten me? thanks very much. |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
