problems with PlichErdman breakup model
Old   January 24, 2013, 08:51
Default problems with PlichErdman breakup model
André Zboralski
azborals is on a distinguished road
hallo everyone,
i have a problem with the PilchErdman breakup model. I modified the PilchErdmanCoeffs
solveOscillationEq false --> true
B1 0,375 --> 0,01; 0,2;1;2
B2 0,236 --> 0,01; 0,2;1;2
to validate a spray model but the droplets and the spray doen´t varry.
Does anybody know how to influence the coeffs?
azborals is offline   Reply With Quote
Old   January 24, 2013, 09:22
Adam
Smed is on a distinguished road
Are you getting any droplet breakup at all? Is your Weber number in the range that could cause breakup?
Smed is offline   Reply With Quote
Old   January 24, 2013, 09:44
André Zboralski
I Think. Before I calculated by using the ReitzKHRT model. Then I changed to PilchErdmann. I red it should be better for spray modelling. Here are some information about the droplets:
C7H16
dropletsize: d = 0 ...2e-4 m
velocity: u = 20 ... 40 m/s
--> there must be any droplet breakup!?
Is there anything to activate if using PilchErdmann in addition to the selection of the model? Do you know something about the value of the coeffs?
Old   January 24, 2013, 09:58
Adam
Yeah, that should definitely undergo breakup and it looks like your input is correct. Perhaps this bug could be the problem?
http://www.cfd-online.com/Forums/ope...kup-model.html
Old   January 24, 2013, 10:23
André Zboralski
This should be the reason. The first one is the source code of my opanfoam release. Thank You!!! Do you know in which folder I have to do "wmake" to compile?
Old   January 24, 2013, 10:33
Adam
The PilchErdman model is in OpenFOAM-2.x.x/src/lagrangian/spray/submodels/BreakupModel/PilchErdman , so as long as you use one of the Allwmake scripts above that directory, it will recompile the contents of that directory. I would run Allwmake from /src/lagrangian.
Old   January 24, 2013, 10:57
André Zboralski
Thanks! I will try it and give a feedback!
Old   January 30, 2013, 08:53
André Zboralski
It works!!! Thank you!
breakup, coeffs, erdman, pilch
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
non-linear k-epsilon model implementation problems Saidi Main CFD Forum 2 March 4, 2010 13:23
Another breakup model Jay, Choi Siemens 5 January 13, 2010 13:36
atomization model vs breakup model Jay Siemens 7 January 24, 2008 19:51
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 04:37
