Reusing the inlet time directories in timeVaryingMappedFixedValue |
January 24, 2013, 10:22 |
Rep Power: 15 |
I’m using the timeVaryingMappedFixedValue as boundary condition for my inlet in an LES. For the inlet I have time folders from another simulation that I use. These are placed in constant/boundaryData/INLET/. Is there a way to reuse the data in INLET automatically when the LES simulation has run through the time provided in the INLET. If I just let the LES run further beyond the time provided in the INLET directory it keeps the last time folder as inlet data. For example if I have the following time folders containing inlet data for U: constant/boundaryData/INLET/0/U constant/boundaryData/ INLET /1/U constant/boundaryData/ INLET /2/U constant/boundaryData/ INLET /3/U And I put my endTime to 7 the U INLET boundary conditions for simulation times 4, 5, 6 and 7 are taken from folder 3. Instead I would like it to start again from the first time folder given and reuse the data in INLET. So for simulation time 4, 5, 6, 7 it would use the U provided in INLET/0, 1, 2, 3 and so on. Thank you in advance Nina |
Display Modes | |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
How to find a good time scale strategy? | StefanG | CFX | 19 | June 8, 2012 08:41 |
Problem with FloatingObject | Leech | OpenFOAM Running, Solving & CFD | 10 | March 29, 2012 15:24 |
