January 24, 2013, 11:27 |
High diffusion in interFoam
Andrea Ferrari
i am simulating a meniscus that moves in capillary tubes of different shape with small contact angle (from 1° up to 30°). I have observed a very large diffusion of the interface which sometimes leads to non-physical or not-expected results. I was wondering if i can limit diffusion without without touching cAlpha, which is set to 1 at the moment, maybe playing with schemes for convective terms. Which schemes can be used in interFoam to limit diffusion? This is how my fvScheme looks like: Code:
ddtSchemes { default Euler; } gradSchemes { default leastSquares; // grad(U) Gauss linear; // grad(alpha1) Gauss linear; } divSchemes { div(rho*phi,U) Gauss limitedLinearV 1; div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss interfaceCompression; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p_rgh; pcorr; alpha1; } Code:
solvers { pcorr { solver PCG; preconditioner DIC; tolerance 1e-10; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.05; } p_rghFinal { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0; } U { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; } UFinal { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; } PIMPLE { momentumPredictor yes; nCorrectors 3; nNonOrthogonalCorrectors 1; nAlphaCorr 1; nAlphaSubCycles 3; cAlpha 1; } Code:
application interFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.22; deltaT 0.000000001; writeControl adjustableRunTime; writeInterval 0.01; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.1; maxAlphaCo 0.1; maxDeltaT 0.01; andrea |
January 24, 2013, 15:59 |
Anton Kidess
Rep Power: 29 |
Instead of vanLeer you can use MULES or SuperBee, both of which should be more compressive. Don't expect too much though.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
January 31, 2013, 04:08 |
Andrea Ferrari
Thanks Anton, i'll give them a try.
best andrea |
Alternatives for InterFoam - High Viscosity Ratio Problem | saba_saeb | OpenFOAM | 3 | November 13, 2012 16:57 |
Non-physical alpha1 with interFoam and high contact angles | steph79 | OpenFOAM Running, Solving & CFD | 7 | November 6, 2012 04:17 |
InterFoam Artificially High Velocities | andersson.j | OpenFOAM Running, Solving & CFD | 0 | February 8, 2011 10:43 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
