-   -   Law of the wall: k-omega vs. Spalart-Allmaras (simpleFoam) (http://www.cfd-online.com/Forums/openfoam-solving/112283-law-wall-k-omega-vs-spalart-allmaras-simplefoam.html)
MrFourier January 25, 2013 06:46
1 Attachment(s)
Hi everyone,
I'm new to OpenFOAM, and in preparation for a more complex simulation I'm currently working on evaluating some turbulence models on a simple mesh.
I have a 2D-flow between two smooth no-slip walls. Boundary conditions on inlet and outlet are periodic, except for a pressure jump. I'm using simpleFoam and tried out both k-omega SST and Spalart-Allmaras turbulence models, with all default coefficients, and compared the results. This plot is for a mesh with a wall y+ of 0.5 (I get the same results using different mesh resolutions).
Attachment 18471
I'm not sure what I'm supposed to get, but I figure the k-omega SST results are quite good, whereas the Spalart-Allmaras results look unusable. The Spalart results can't be the way they're supposed to be, can they? I must be doing something wrong!
Except for the nuTilda file, the settings are exactly the same, so here's my nuTilda file:
dimensions      [ 0 2 -1 0 0 0 0 ];
internalField  uniform 1.e-5;//0.05;
boundaryField
    inlet
        type            cyclicAMI;
    outlet
        type            cyclicAMI;
    wall
        type            fixedValue;
        value          uniform 0;
    "sym(A|B)"
        type            symmetryPlane;
Does anyone have an idea how to fix this? :confused:
Are there any other configuration files that I should post here?
Thank you!
EDIT: Btw, this is OF 2.1
vwibaut March 22, 2013 04:54
Hi MrFourier,
Do you find something? I have a similar problem
Thanks for your help
kiddmax January 22, 2014 15:33
Hi Valentin,
Did you find something?
Best
Ye
kovamaniac May 29, 2014 00:59
Hi.
As I am having trouble in making the SST run, could you please post the rest of your files for the setup? My solution does not converge and I cannot understand why.
RodriguezFatz June 2, 2014 06:49
Anastasios what is the problem? Post your relevant settings.
kovamaniac June 4, 2014 03:42
Hi Philipp.
My settings are the following:
Initial conditions for U
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 68.4 0. 0. );
boundaryField
farfield2
type empty;
farfield1
type empty;
inflow
type fixedValue;
value uniform (68.4 0. 0.);
outflow
type zeroGradient;
symmetry
type symmetryPlane;
wall
type fixedValue;
value uniform (0. 0. 0.);
top
type slip;
Initial conditions for P
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.;
boundaryField
farfield2
type empty;
farfield1
type empty;
inflow
type /*freestreamPressure;*/zeroGradient;
outflow
type zeroGradient;
symmetry
type symmetryPlane;
wall
type zeroGradient;
top
type slip;
Initial conditions for k
internalField uniform 0.001052676;
boundaryField
farfield2
type empty;
farfield1
type empty;
inflow
type fixedValue;
value uniform 0.001052676;
outflow
type zeroGradient;
symmetry
type symmetryPlane;
wall
type fixedValue;
value uniform 0;
top
type slip;
Initial conditions for omega
dimensions [0 0 -1 0 0 0 0];
internalField uniform 8550;
boundaryField
farfield2
type empty;
farfield1
type empty;
inflow
type fixedValue;
value uniform 8550;
outflow
type zeroGradient;
symmetry
type symmetryPlane;
wall
//type fixedValue;
type omegaWallFunction;
//value uniform 1.581e+08;
value uniform 1;
top
type slip;
Initial conditions for nut
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
farfield2
type empty;
farfield1
type empty;
inflow
type calculated;
value uniform 0;
outflow
type calculated;
value uniform 0;
symmetry
type symmetryPlane;
wall
type nutUSpaldingWallFunction;
value uniform 0;
top
type slip;
The system files are:
solvers
p GAMG
preconditioner DIC;
mergeLevels 1;
smoother GaussSeidel;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 100;
cacheAgglomeration on;
tolerance 1e-07;
relTol 0.01;
U GAMG
preconditioner DILU;
mergeLevels 1;
tolerance 1e-07;
relTol 0.1;
k GAMG
mergeLevels 1;
tolerance 1e-07;
relTol 0.1;
omega GAMG
mergeLevels 1;
tolerance 1e-07;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
relaxationFactors
p 0.3; //0.3 original!!
U 0.7;
k 0.7;
omega 0.7;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(U) Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwindV grad(U);
div(phi,k) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
My meshes come from NASA website and the y+ value is below 1 everywhere, that's why I do not use wall functions. I am not sure about the top boundary condition for which I put "slip".
With the above settings the solution converges but the values are strange; I have values in the flow field greater than the input velocity.
RodriguezFatz June 4, 2014 03:51
Ok, so you have a flat plate on the bottom, inlet on the left and outlet on the right?
At your inlet you put in some constant velocity profile. Now, at the bottom wall a boundary layer develops with increasing size along the flow direction. In this boundary layer the velocity is low. But the mass flow through each vertical line (integrated) must be constant. Thus, if you have a lower velocity at the bottom you must get a higher value at some other places.
kovamaniac June 4, 2014 04:40
You are correct. Mass conservation. Thank you very much.
RodriguezFatz June 4, 2014 04:47
Does it work if you set inlet and outlet to zerogradient and the top wall to some fixed velocity value?
kovamaniac June 4, 2014 06:01
This reminds me the way I was doing it with fluent where the top was also an inflow bc. Let me try this and I will let you know.
kovamaniac June 8, 2014 10:58
2 Attachment(s)
Exactly the same situation.
My main problem seems to be the pressure convergence. In both the very fine mesh (~2100000 cells) and the coarse presents a very oscillatory behavior. In the fine mesh after some iterations it seems to somehow blow up.
Please find attached the residuals for both cases. I tried to reduced the order of the Laplacian but the same.
kovamaniac June 8, 2014 11:04
1 Attachment(s)
Also I am not sure about the accurace as the results differ significantly form NASA's. I do not so much care about the values but from the fact that my results do not follow well the law of the wall.
RodriguezFatz June 10, 2014 03:57
I would try to run it with gradient limiters. Go for
default cellMDLimited Gauss linear 1.0;
and see what happens.
In my experience, the convergence of the k-omega-sst model strongly depends on the gradient limiters.
kovamaniac June 10, 2014 09:31
The same behavior and convergence in higher values.
In any case, I solved the issue with the inaccuracy.
FYI, the wallShearStress DOES NOT WORK FOR LOW-RE GRIDS.
Calculating u_tau with the wallGradU utility resulted in correct results.
RodriguezFatz June 10, 2014 09:43
1) Did you deactivate ("//") the gradients for U and p and set all the gradients as I suggested?
2) Are you sure, you use the correct syntax for relaxation factors? I use them like
http://www.openfoam.org/docs/user/fvSolution.php
kovamaniac June 12, 2014 03:35
I use the setup for the fvSolution file suggested for the simpleFoam at the link you gave; however this is for a laminar case -this is what it says, despite having k and epsilon defined.
If I use the gradscheme you propose for default, the result is convergence in higher values again with this small oscillation. I cannot understand why. At the moment I compromise with this as the results at least for the flat plate flow are satisfactory. To be honest I can understand the difference of the solver schemes, but I do not have the intuition. It is too mathematical for me and I have not been taught such advanced linear algebra topics.
I will use some more complicated models and let you know.
RodriguezFatz June 12, 2014 03:41
Can you upload the complete setup somewhere?
kovamaniac June 17, 2014 04:08
Finally,
I followed your advice and changed the gradient schemes. That behaved correctly.
However, the most important issue for the accuracy results was to understand that the wallShearStress utility outputs in m2/s2, which is Pa/rho and not Pa. That was a big mistake which took me a lot to understand -to be honest I hadn't paid attention.
Thank you very much for your help anyway.
