Simulationtime for scalarTransportFoam
Old   January 25, 2013, 12:19
Default Simulationtime for scalarTransportFoam
Sören
despaired student is on a distinguished road
I've just a short question about scalarTransportFoam.
There are no eddys, turbulences or other transient parts in my velocity field. Now I'm simulating the distribution of a scalar in this velocity-field. The question ist when to stop the simulation? I thought about:
a) measure the scalar-input and -output. When conservation of mass is reached then stop the simulation. If this is correct how would you justify this as the criterium to stop at?
b) make sample-pictures at different time-steps. When there are no changes in the sample-pictures of the concentration field one can say that the simulation should be stoped.
c) measure the way a scalar moves from inlet to outlet. Divide this way by the velocity (average velocity or something like this) and then you get the timestep to that you have to run the simulation.
Could you give me a short feedback/comment...the answer to my initial question is also welcome
Cheers
despaired student is offline   Reply With Quote
Old   January 25, 2013, 20:54
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
If your velocity field is steady, I think the scalar distribution reaches a steady
state at some time. You can monitor the time history of scalar distributions at
some points using the probes function and stop simulation when variations
become smaller than your criterion. I think you can estimate the approximate
time needed to reach steady state by the method you wrote in c.
Hope that helps,
Fumiya
fumiya is offline   Reply With Quote
Old   January 26, 2013, 15:05
Sören
Hi fumiya,
thanks for your reply. You are right the probe utility should work fine in my case...haven't thought about it...my bad
regards
