how to obtain pressure in outlet from solution? |
January 26, 2013, 07:40 |
Ehsan
Rep Power: 26 |
I want to obtain pressure at a outlet patch.I don't know the pressure there.then i can't set pressure fixed at this outlet.in return pressure at this patch should be obtained from solution.then how it should be done.clearly say what boundary condition is better to set at such a patch?
thank to someone that reply! |
January 27, 2013, 12:09 |
Ehsan
Rep Power: 26 |
any replacement for pressure at outlet?is temperature sufficient?(we although know the pressure from an article want to obtain it for verifying our results.is it possible or give true results by this scheme?)
Display Modes | |
UDF to adjust pressure outlet | a.lynchy | FLUENT | 4 | February 15, 2021 00:50 |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
pressure oscillation near pressure outlet boundary | kino | Main CFD Forum | 5 | April 13, 2011 11:03 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 06:52 |
Pressure difference at outlet | Nessan | CFX | 3 | April 18, 2004 00:20 |
