January 28, 2013, 06:15 |
Negative pressures
Elio Bufi
Hi foamers,
I have to simulate the flow in a cylindrical duct (diameter=0.24 mm) . The flow is made by liquid (e.g. water) that is injected in the duct from a cubic capacity at 160 bar and arrives in another cubic capacity at 1.5 bar. The geometry is pretty simple and is shown in the attached image "GEOMETRY". So, I simulate the case with InterPhaseChangeFoam because I want to study the cavitation occurring in the duct. However I obtain high negative pressures , as shown in the figure "p_results". I don't konw how to interpret these values. Are these values relative to a pressure reference value or are they absolute values? In the latter case: how is it possible to obtain negative absolute pressure without a solver crash? I attach the p_rgh boundary condition in the 0 folder: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0]; internalField uniform 160e5; boundaryField { inlet { type fixedValue; value uniform 160e5; U U; rho rho; psi none; gamma 1; } outlet { type fixedValue; value uniform 1.5e5; } wall { type zeroGradient; } cyl { type zeroGradient; } frontBack { type empty; } } // ************************************************** *********************** // Thank you in advance for your attention. |
January 28, 2013, 11:04 |
Eric Robertson
Your output in Paraview are always relative pressures with the datum being atmospheric (I suppose unless otherwise specified).
January 29, 2013, 03:08 |
Elio Bufi
Thank you for tour reply msuaeronautics.
Can you explain me how to set the reference pressure in OpenFoam or Paraview in order to get only positive relative pressures? |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
