[swak4Foam] Interface contour - interFoam
Old   November 13, 2012, 10:39
Default Interface contour - interFoam
P.M.Bronow
PrzemekPL is on a distinguished road
Hello Everybody,
I'm using OF 2.1.1 and interFoam for the flow simulations with the free surface.
Thanks to swak4Foam I'm able to write out some results during the run. What I'm interseted in is the alpha1 field at a given cutting plane.
My controlDict:
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
functions
cuttingPlane_vtk
type surfaces;
functionObjectLibs ("libsampling.so");
outputControl outputTime;
surfaceFormat vtk;
fields ( alpha1 );
interpolationScheme cellPoint;
surfaces
cuttingPlane
type cuttingPlane;
planeType pointAndNormal;
pointAndNormalDict
basePoint (0 0 0);
normalVector (0 0 1);
interpolate true;
Once I get .vtk files I can load them into paraview, plot the contour alpha1=0.5 and save the contour data as .csv file.
So, my question is if steps which I perform in paraview can be added to the swak4foam procedure?
Thanks in Advance for any help!!!
PrzemekPL is offline   Reply With Quote
Old   November 13, 2012, 12:49
Michiel
michielm is on a distinguished road
I think you can set your surfaceFormat to 'raw' and export the cutting plane with alpha1=0.5
I don't know exactly how this cutting plane works, but the code below will export just x,y,z locations for the alpha1=0.5 surface
DropSurface
       type            surfaces;
       functionObjectLibs
           "libsampling.so"
       outputControl   timeStep;
       outputInterval  150;
       surfaceFormat   raw;
       fields
           //alpha1
       surfaces
        constantIso
        	type            isoSurfaceCell;    // always triangulated
        	isoField        alpha1;
        	isoValue        0.5;
        	interpolate     false;
        	regularise      false;              // do not simplify
michielm is offline   Reply With Quote
Old   November 14, 2012, 08:48
P.M.Bronow
@michielm, thank you for your answer.
Your method works, but it gives the cooordinates of the whole surface.
The question is how to do it for a particular cutting plane? :-)
So far, I use this method to export isoSurface (.raw or .vtk) during the run and use some other software (i.e., matlab) to get the free surface contour at a given plane.
Integrating these steps into the sampling functions would save me a lof of work :-)
thanks!
Old   November 20, 2012, 20:04
Assistant Moderator
Bernhard Gschaider
thanks!
If I understand you correctly you want to cut an iso-surface with a plane to get a "string"/line?
I'm afraid you can't do that with swak4Foam. I'm not quite sure whether there are methods in OF that support that (cutting two surfaces) out-of-the-box
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 30, 2013, 14:09
Mieszko Młody
ziemowitzima is on a distinguished road
Hi
Do you know maybe how to extract isosurface of the field (e.g. field T, isosurface for T = 0) during runtime ?
I would need it coordinate in my solver.
Thanks
ZM
ziemowitzima is offline   Reply With Quote
contour, free surface, interfoam, swak4foam
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
How to have sharp interface in nano scale two phase flow problem using interFoam hosseinfathi OpenFOAM Programming & Development 10 April 9, 2017 09:07
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
the interface reconstruction in InterFoam young_Cao OpenFOAM Running, Solving & CFD 3 June 13, 2012 06:45
