Home > Forums > OpenFOAM Running, Solving & CFD
Novice question
Old   January 29, 2013, 14:53
Default Novice question
Anonymous
Industrial_CFD is on a distinguished road
Hi All,
I am trying to get an LES case to converge, and I am having some difficulty. The case runs fine in FLUENT, but the pressure residual blows up in OpenFOAM. My mesh is great, timestep is really small (Co <0.05), so I believe my BCs are the problem. In FLUENT the outlet is set to outlet-vent. Can someone tell me how to set that in OpenFOAM. I jus want to double check what I've done.
Currently for U I have:
Outlet
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
For P I have:
OUTLET
type fixedValue;
value uniform 0;
Cheers
Industrial_CFD is offline   Reply With Quote
Old   January 30, 2013, 05:55
Tom Fahner
tomf is on a distinguished road
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hello Anonymous,
It seems indeed your boundary conditions may lead to these divergence problems, similar problems where found here:
LES for wind over buildings
Maybe they have found a solution,
regards,
Tom
tomf is offline   Reply With Quote
Old   January 30, 2013, 10:52
Default Thanks
Anonymous
Thanks Tom,
I had a look at the forum, and it helped. I had a question...what outlet Boundary condition in OpenFOAM would match an outlet-vent condition in FLUENT. In FLUENT, the outlet-vent condition allows backflow, but both the outflow and backflow have a pressure drop across the vent, proportional to the velocity (either in or out). Like a loss coefficient for a valve.
Cheers
Old   January 30, 2013, 11:30
Eric R
msuaeronautics is on a distinguished road
Originally Posted by Industrial_CFD View Post
Thanks Tom,
Cheers
I'd take a look at this:
http://www.foamcfd.org/Nabla/guides/...ml#x32-1640293
Maybe pressureInletVelocity or something similar for U?
msuaeronautics is offline   Reply With Quote
Old   January 30, 2013, 11:32
Tom Fahner
I don't think there is a standard boundary condition available that is similar. I did experiment a bit with LES, but I am not an expert. Also I have no experience with Fluent, so I guess I am not the best person to give you more advice.
I only have one more suggestion:
The way you prescribe the Fluent boundary condition sounds like a sponge layer with backflow calculated based on pressure difference, maybe it helps to use
pressureInletOutletVelocity
instead of
inletOutlet with inletVelocity uniform(0 0 0)?
Regards,
Tom
Old   January 30, 2013, 12:43
Default Reply
Anonymous
Thanks Tom,
I will give that a try, they both sound similar. Boundary conditions for LES are very difficult, especially if they arent cyclical.
Thanks again,
Cheers
Thread Tools
Trackbacks are On
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 14:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 16:26
question on bounday layer modeling Wen Long Main CFD Forum 2 November 12, 2005 18:29
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
Philosophical CFD question Richard Howe Main CFD Forum 14 June 17, 2001 14:41
