relaxation factor for PISO algorithm
Like Tree1Likes
  • 1 Post By wyldckat
Old   January 30, 2013, 16:48
Default relaxation factor for PISO algorithm
Sasan Ghomi
sasanghomi is on a distinguished road
Hi every body,
I have a question about relaxation factor :
sonicTurbDymEngineFoam is a transient solver for compressible flow with mesh motion.(OP-1.6-ext)
It uses PISO algoritm for solving equations.when I use relaxation factor in a case with this solver I get correct result.Do you think using of relaxation factor in PISO algorithm is wrong??? why???
In a header file of the source code of this solver I saw this code :
UEqn.relax();
thanks,
Sasan.
sasanghomi is offline   Reply With Quote
Old   February 2, 2013, 05:51
Retired Super Moderator
Bruno Santos
In order to give a bump to this thread, here's what I answered Sasan the other day, through private messaging:
Originally Posted by wyldckat
Hi Sasan,
I don't know much about this. All I know is:
  1. Both PISO and SIMPLE can be used for transient simulations.
  2. PISO algorithm is described here: http://openfoamwiki.net/index.php/Th...hm_in_OpenFOAM
  3. SIMPLE algorithm is described here:http://openfoamwiki.net/index.php/Th...hm_in_OpenFOAM
  4. Then there is PIMPLE, which is a mix of PISO+SIMPLE... and I quote:
    Originally Posted by alberto View Post
    PISO simply does not iterate over the equations: it solves alpha, Theta, U, p, k, epsilon and proceeds in time.
    PIMPLE is a combination of PISO and SIMPLE. In other words you can have outer correctors, if you set the appropriate keyword in the fvSolution PIMPLE sub-dictionary.
Therefore, the relaxation factors you're talking about may depend on whether you're using PISO or PIMPLE.
You might have gotten a better answer if you had asked in the public forum...
Best regards,
Bruno
aow likes this.
Relaxation factor Benzaa Main CFD Forum 1 August 18, 2009 07:27
Relaxation and convergence sammi Phoenics 0 March 20, 2008 03:32
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
