Cloud Function Objects question?
Dear foamers
I just wonder whether anyone used the VoidFraction under the src/lagrangian/intermediate/submodels/CloudFunctionObjects? I have a set of two phase flow data (bubble/fluid) with lagrangian tracking and I am trying to calculate the void fraction of the flow field. I have put the followings in the kinematicCloudProperties: Code:
cloudFunctions Code:
dimensions [0 0 0 0 0 0 0]; |
I have the exact same issue as you, and cannot get it to work either. I have filed a bug report on it: http://www.openfoam.org/mantisbt/view.php?id=829
Hello Jie, Did you solved the void fraction issue in CollidingParcel case ? can you please share their file or suggest me where and how to incorporate the line " td.cloud().functions().postMove(p, cellI, dt);" in CollidingParcel.C. Moreover, dt is not mention in the CollidingParcel.H file. so it will give an error while compiling I am using OF-2.2.2. |
