Problem with inconsistent patches (AMI, interDyMFoam)
Old   January 30, 2013, 09:09
Default Problem with inconsistent patches (AMI, interDyMFoam)
Anon
jrrygg is on a distinguished road
Hi!
I have been working on simulating a case with a rotating Pelton turbine using the InterDyMFoam-solver and the AMI-interface in OpenFOAM 2.1.1.
When I try to run the case I get the following error-message:
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to entire mesh
Reading field p_rgh
Reading field alpha1
Reading field U
AMI: Creating addressing and weights between 7602 source faces and 7602 target faces
AMI: Patch source weights min/max/average = 1, 1.009881271, 1.000225935
AMI: Patch target weights min/max/average = 1, 1.009881271, 1.000225935
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
Reading g
Calculating field g.h
PIMPLE: Operating solver in PISO mode
time step continuity errors : sum local = 3.598673146e-08, global = -3.598673146e-08, cumulative = -3.598673146e-08
GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 1.848725019e-06, No Iterations 6
time step continuity errors : sum local = 6.652957099e-14, global = -1.355912807e-14, cumulative = -3.598674502e-08
Courant Number mean: 9.852053092e-07 max: 0.006905813148
Starting time loop
Interface Courant Number mean: 0 max: 0
Courant Number mean: 9.832388315e-07 max: 0.00689202909
deltaT = 1.196172249e-07
Time = 1.196172249e-07
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 1.196172249e-07 transformation: ((0 0 0) (1 (0 3.961438105e-06 0)))
AMI: Patch source weights min/max/average = 0.9999103424, 1.009878216, 1.000226318
AMI: Patch target weights min/max/average = 0.9999695281, 1.009919616, 1.000226192
Execution time for mesh.update() = 0.73 s
time step continuity errors : sum local = 7.958082654e-14, global = -1.621905271e-14, cumulative = -3.598676123e-08
GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 2.428583894e-06, No Iterations 5
time step continuity errors : sum local = 3.700829363e-10, global = 1.683202693e-11, cumulative = -3.596992921e-08
MULES: Solving for alpha1
Phase-1 volume fraction = 1.076158237e-08  Min(alpha1) = 0  Max(alpha1) = 1
Phase-1 volume fraction = 2.152316475e-08  Min(alpha1) = 0  Max(alpha1) = 1
Phase-1 volume fraction = 3.228474712e-08  Min(alpha1) = -2.818921773e-24  Max(alpha1) = 1
Phase-1 volume fraction = 4.304632949e-08  Min(alpha1) = -4.654056954e-25  Max(alpha1) = 1
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.007821959321, No Iterations 6
time step continuity errors : sum local = 3.381447662e-10, global = -1.188843696e-10, cumulative = -3.608881358e-08
GAMG:  Solving for p_rgh, Initial residual = 0.04888923893, Final residual = 0.0003682615198, No Iterations 2
time step continuity errors : sum local = 1.903051747e-09, global = -5.90183726e-10, cumulative = -3.66789973e-08
GAMGPCG:  Solving for p_rgh, Initial residual = 0.009021835592, Final residual = 2.580695706e-09, No Iterations 5
time step continuity errors : sum local = 1.44550723e-14, global = -6.293997608e-17, cumulative = -3.667899737e-08
--> FOAM FATAL ERROR:
Cannot find face 471634 in any of the patches
12
jetinlet
jetwalls
BBC
MBC
TBC
statopening
rotopen
rotsym
statinlet
statsym
AMI1
AMI2
It seems your patches are not consistent with the mesh : internalFaces:471604  total number of faces:542821
    From function label polyBoundaryMesh::whichPatch(const label faceIndex) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 541.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::polyBoundaryMesh::whichPatch(int) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3  void Foam::fvMatrix<double>::setValuesFromList<Foam::UList>(Foam::UList<int> const&, Foam::UList<double> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#4  Foam::fixedInternalValueFvPatchField<double>::manipulateMatrix(Foam::fvMatrix<double>&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#5  Foam::incompressible::RASModels::kEpsilon::correct() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/interDyMFoam"
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted (core dumped)
I think the problem might be since I manually removed some boundaries and faces generated by blockMesh from the boundary-file, but even if I add up the faces I removed, I can not find the mentioned face 471634.
Any advice on how I can solve this? I will be happy to provide additional information if this is not sufficient.
The boundary file BEFORE I deleted outside, inside, top and bottom:
17
outside
    type            patch;
    nFaces          0;
    startFace       479206;
inside
    type            patch;
    nFaces          20;
    startFace       479206;
top
    type            patch;
    nFaces          2;
    startFace       479226;
bottom
    type            wall;
    nFaces          9;
    startFace       479228;
jetinlet
    type            wall;
    nFaces          25;
    startFace       479237;
jetwalls
    type            wall;
    nFaces          494;
    startFace       479262;
BBC
    type            wall;
    nFaces          9792;
    startFace       479756;
MBC
    type            wall;
    nFaces          9547;
    startFace       489548;
TBC
    type            wall;
    nFaces          9462;
    startFace       499095;
statopening
    type            wall;
    nFaces          600;
    startFace       508557;
rotif
    type            wall;
    nFaces          0;
    startFace       509157;
rotopen
    type            wall;
    nFaces          5822;
    startFace       509157;
rotsym
    type            symmetryPlane;
    nFaces          6347;
    startFace       514979;
statinlet
    type            wall;
    nFaces          9727;
    startFace       521326;
statsym
    type            symmetryPlane;
    nFaces          4166;
    startFace       531053;
AMI1
    type            cyclicAMI;
    nFaces          0;
    startFace       535219;
    neighbourPatch  AMI2;
    transform       noOrdering;
    surface
AMI2
    type            cyclicAMI;
    nFaces          0;
    startFace       535219;
    neighbourPatch  AMI1;
    surface
jrrygg is offline   Reply With Quote
Old   January 31, 2013, 10:25
maHein is on a distinguished road
I think there are some serious problems with your mesh, since none of your AMI patches contains any faces. Have you checked your mesh with paraview? Maybe you could post some images?
maHein is offline   Reply With Quote
Old   January 31, 2013, 12:39
Anon
Thank you for your reply!
I also wondered about why it had 0 faces, but it seems to be the same in the propeller-tutorial which I have based my case on. When I look at the AMI-patches in paraView, however, it looks like they have faces. I will post some images tomorrow morning so it will be clearer.
Old   February 1, 2013, 03:23
Anon
Here are some pictures of my mesh:
Mesh consisting of a stationary (outer) domain with jet inlet, and a rotating (inner) domain with buckets
AMI1 / AMI2 patch
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
openFoam 2.1.x: creating AMI patches from a cylinder. ebah6 OpenFOAM Running, Solving & CFD 5 March 26, 2012 18:06
problem occurs in interDyMFoam solver jignesh_thaker2007 OpenFOAM 2 March 18, 2012 21:11
Lagrangain tracking with sliding mesh with AMI patches jiejie OpenFOAM Running, Solving & CFD 0 March 6, 2012 23:59
error using interDyMFoam with kOmegaSST to simulate sloshing anmartin OpenFOAM Running, Solving & CFD 0 July 20, 2010 13:21
