Home > Forums > OpenFOAM Running, Solving & CFD
groovyBC issue - k and epsilon
Like Tree1Likes
Old   February 20, 2014, 17:58
Assistant Moderator
Bernhard Gschaider
Originally Posted by LamiaOF2.1 View Post
hello
I am trying to program with groovy BC this equation
w=alpha*Uref/sqrt(C)*Yref
I tried this but it gives me an error message
inlet
type groovyBC;
variables "Uref=5;Yref=0.5;alpha=0.33;C=0.09;
omg=((Uref*alpha)/(sqrt(C)*Yref));"
valueExpression "omg";
so is that make any sens?
Error message would be most helpful.
Anyway: I'm pretty sure (too lazy to bother checking the code) that is not a valid character in a fieldname. Maybe that is the problem
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 22, 2014, 09:34
Default groovy
  #22
Lamia
LamiaOF2.1 is on a distinguished road
hello again
well I tried this
inlet
type groovyBC;
variables "Uref=5;Yref=0.5;alpha=0.33;C=0.09;omg=((Uref*alph a)/(sqrt(C)*Yref));"
and here is the error message
--> FOAM Warning :
From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict)
in file groovyBCFvPatchField.C at line 131
No value defined for U on inlet therefore using 460{(0 0 0)}
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
--> FOAM Warning :
No value defined for omega on inlet therefore using 460{0}
bounding omega, min: 0 max: 1 average: 1
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#5 at kOmegaSST.C:0
#6 Foam::incompressible::RASModels::kOmegaSST::F2() const in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#7 Foam::incompressible::RASModels::kOmegaSST::F23() const in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#8 Foam::incompressible::RASModels::kOmegaSST::kOmega SST(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#9 Foam::incompressible::RASModel::adddictionaryConst ructorToTable<Foam::incompressible::RASModels::kOm egaSST>::New(Foam::GeometricField<Foam::Vector<dou ble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#10 Foam::incompressible::RASModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#11
in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/simpleFoam"
#12 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#13
Exception en point flottant
please; I need help
LamiaOF2.1 is offline   Reply With Quote
Old   February 22, 2014, 12:32
Assistant Moderator
Bernhard Gschaider
hello again
well I tried this
inlet
type groovyBC;
--> FOAM Warning :
--> FOAM Warning :
At this place groovy tells you that during initializiation it needs a entry "value", doesn't find one and therefor assumes 0. Which leads to the "divide by zero" below.
The reason why it needs value is that it can't evaluate valueExpression during intialization because it can't be sure that all the needed fields are already loaded into memory. The value is only used during the first timestep
Don't know what else I can do to alert people to this apart from issuing a warning. Make it fail?
#2 Uninterpreted:
#5 at kOmegaSST.C:0
#11
#13
please; I need help
Old   February 23, 2014, 09:47
Default groovy bc
  #24
Lamia
hello Bernhard
I am sorry for my ignorance but I am new user of OpenFoam
I complitely understand you but I don't know how to enter this missing value
is it that way?
internalField uniform 400;// calcul omega
boundaryField
inlet
type groovyBC;
value uniform 400;
cause it keeps giving me an error message
Create time
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM Warning :
kOmegaSSTCoeffs
alphak1 0.85034;
alphak2 1;
alphaOmega1 0.5;
alphaOmega2 0.85616;
gamma1 0.5532;
gamma2 0.4403;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
c1 10;
Cmu 0.09;
alphaK1 0.85034;
alphaK2 1;
b1 1;
F3 false;
Creating finite volume options
No finite volume options present
SIMPLE: convergence criteria
field p tolerance 1e-06
field U tolerance 1e-06
field "(k|epsilon|omega)" tolerance 1e-06
Starting time loop
streamLine : automatic track length specified through number of sub cycles : 5
Time = 1e-05
swak4Foam: Allocating new repository for sampledGlobalVariables
--> FOAM Warning :
From function gaussConvectionScheme
in file finiteVolume/convectionSchemes/gaussConvectionScheme/gaussConvectionScheme.H at line 123
Reading "/home/openfoam/Bureau/Kwsstmodelprofilomegagroovybc/system/fvSchemes.divSchemes.div(phi,U)" at line 33
Unbounded 'Gauss' div scheme used in steady-state solver, use 'bounded Gauss' to ensure boundedness.
To remove this warning switch off 'boundedGauss' in "/opt/openfoam220/etc/controlDict"
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00654075, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00985678, No Iterations 647
time step continuity errors : sum local = 1.11693e-07, global = -2.60785e-09, cumulative = -2.60785e-09
--> FOAM Warning :
Reading "/home/openfoam/Bureau/Kwsstmodelprofilomegagroovybc/system/fvSchemes.divSchemes.div(phi,omega)" at line 35
DILUPBiCG: Solving for omega, Initial residual = 0.0790587, Final residual = 0.000242277, No Iterations 1
bounding omega, min: 0 max: 1.80129e+06 average: 2158.86
--> FOAM Warning :
Reading "/home/openfoam/Bureau/Kwsstmodelprofilomegagroovybc/system/fvSchemes.divSchemes.div(phi,k)" at line 34
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0373248, No Iterations 1
#2 Uninterpreted:
#5 at kOmegaSST.C:0
#8 Foam::incompressible::RASModels::kOmegaSST::correc t() in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#10 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#11
thank you for your help and patiente...
Old   March 1, 2015, 08:16
maalan is on a distinguished road
Haven't looked at the IB-stuff yet so I can't say anything clever here
Hi Bernhard! Did you already have a look at the IBM?
I use the foam-extend-3.1 release and would like to compute some 'swakExpressions' but I am stuck up to the moment... I have to say that I did compute these expressions in a conformal mesh successfully.
In my case, I try to simulate the flow past a cylinder by using the IB method. I would like to calculate, for instance:
        type swakExpression;
        valueType patch;
        patchName ibCylinder;
        accumulations (
            sum
        expression "(vorticity^normal())&vectorAconst*area()";
        verbose true;
I tried to integrate this variable over the cylinder surface in each timeStep, but unfortunately I obtain always zero.
How do you think I could manage this issue?
Any help would be appreciated.
Thanks!
maalan is offline   Reply With Quote
Thread Tools
Trackbacks are On
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 13 November 4, 2013 15:13
epsilon groovyBC problem Thom OpenFOAM Running, Solving & CFD 5 October 26, 2012 05:16
epsilon and K blowing up. sivakumar OpenFOAM Running, Solving & CFD 1 October 25, 2012 04:50
K Epsilon convergance issue Ollie OpenFOAM 2 April 18, 2011 08:28
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
