February 4, 2013, 21:40 |
PISO in FLUENT vs. OpenFOAM
Anonymous
Rep Power: 14 |
Hi guys,
I am trying to get an LES case set up in openfoam, and I have been trouble shooting with FLUENT. FLUENT iterates PISO until the specified max iterations are reached ( or until convergence). Is there anyway to run pisoFOAM like this? Would this implementation be pimpleFoam? Cheers |
February 5, 2013, 10:43 |
Christian Lucas
Rep Power: 17 |
have a look at pimpleFoam. However, as I know, pimpleFoam doesn't check if the solution is converged. You have to programm it (a guess 10 lines of code) yourself. Kind Regards, Christian |
February 7, 2013, 11:14 |
Update
Anonymous
Rep Power: 14 |
What is really amazing is that OpenFOAM won't converge compared to the same settings in FLUENT (I think anyway). FLUENT handles the case easily, whereas OpenFOAM cannot converge the pressure term.
It is really strange. I'm starting to wonder if it is a bug or something. |
February 11, 2013, 06:43 |
Christian Lucas
Rep Power: 17 |
the reason for the different results is not a bug. Some of the internal program structure is different. Fluent has probably internal limiter that help to converge the solution (using numerical diffusion) and openfoam doesn't. What are you trying to simulate. What schemes do you use. What OF version? Is time accuracy important? Kind Regards, Christian |
Display Modes | |
[Other] OpenFoam Mesh to Fluent Mesh, 2D | lordvon | ANSYS Meshing & Geometry | 1 | January 14, 2022 13:20 |
[Commercial meshers] Conversion Fluent cas and dat file to OpenFoam | matteo_gautero | OpenFOAM Meshing & Mesh Conversion | 11 | July 14, 2020 13:09 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Fluent elbow in Openfoam | chemeng | OpenFOAM | 1 | January 21, 2010 04:52 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
