-   -   whats wrong with "sqr(internalField(U.x))"? (http://www.cfd-online.com/Forums/openfoam-solving/112798-whats-wrong-sqr-internalfield-u-x.html)
immortality February 5, 2013 14:27
why OpenFOAM gives an error about U.x?
Selecting turbulence model type laminar
Starting time loop
Time = 5.6e-09
Courant Number mean: 2.703201494e-20 max: 1.290382332e-16
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
swak4Foam: Allocating new repository for sampledGlobalVariables
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 2.073282789e-22, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 2.073273772e-22, No Iterations 2
DILUPBiCG:  Solving for e, Initial residual = 0.0006828527063, Final residual = 3.08254255e-26, No Iterations 2
--> FOAM FATAL ERROR:
Parser Error at "1.34" :"syntax error, unexpected '.', expecting ')'"
"1+(gamma-1)/2*sqr(internalField(U.x))/(gamma*R*internalField(T))"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 802.
FOAM exiting
immortality February 5, 2013 18:07
I've examined other possible types but the error persists.
wyldckat February 5, 2013 20:10
Try:
internalField(U).x
immortality February 12, 2013 13:40
thanks.
are sqr(mag(internalField(U))) and magSqr(internalField(U)) the same?
wyldckat February 12, 2013 18:15
Hi Ehsan,
Right now I'm too sleepy to properly think. I can't figure out how these operations affect vectors, but I think that for matrix tensors those two are not the same.
But if you take a look at the OpenFOAM Programmers Guide, pages 16, 19 and 20, you'll find more specific information on this. Maybe start reading from the beginning of Chapter 1 is the best. This will give you a better understanding of how OpenFOAM handles math operations, which you might have to document in your thesis.
There is a PDF file of the Programmers Guide in the main OpenFOAM source code folder, specifically at "doc/Guides-a4".
Be careful with this guide, because it has some flaws in it... but I think "mag", "sqr" and "magSqr" should all be properly defined.
Best regards,
Bruno
immortality February 13, 2013 07:53
thanks dear Bruno
I had read that before and took a look again.but nothing had write definitely about these terms.I think they are related to groovyBC library.Im going to have a look at its guidance if help.
any idea is appreciated.
immortality February 26, 2013 19:20
have anyone any idea about the expressions?are they different or equivalent certainly?
jherb September 10, 2013 14:59
For the definitions given on http://www.foamcfd.org/Nabla/guides/...sGuidese4.html the two things should be the same.
Originally Posted by immortality (Post 407467)
thanks.
