what does this verbose error mean?
Old   February 6, 2013, 17:14
Default what does this verbose error mean?
immortality's Avatar
Ehsan
immortality is on a distinguished road
everything seemd ok but abruptly this long error displayed.
Courant Number mean: 0.006016320533 max: 0.1094533052
deltaT = 6.881161557e-09
Time = 0.000112601
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.0003065940147, Final residual = 8.088815418e-12, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.0005394431507, Final residual = 5.194598759e-13, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 0.0001163574497, Final residual = 1.838228562e-14, No Iterations 3
DICPCG:  Solving for p, Initial residual = 0.0003997994449, Final residual = 9.948692108e-15, No Iterations 2
time step continuity errors : sum local = 4.188394383e-15, global = 1.42856472e-15, cumulative = -1.407065799e-10
rho max/min : 5.383448835 0.2
DICPCG:  Solving for p, Initial residual = 2.559207164e-06, Final residual = 5.072694151e-17, No Iterations 2
time step continuity errors : sum local = 1.737292932e-16, global = 1.119480219e-17, cumulative = -1.407065687e-10
rho max/min : 5.383355107 0.2
DICPCG:  Solving for p, Initial residual = 1.337395928e-08, Final residual = 9.77091466e-15, No Iterations 1
time step continuity errors : sum local = 4.118995901e-15, global = -3.390387368e-15, cumulative = -1.407099591e-10
rho max/min : 5.383355467 0.2
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 4.398893749e-06, Final residual = 2.914809825e-14, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 2.447614872e-06, Final residual = 2.002688409e-15, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 1.04755499e-06, Final residual = 7.705584358e-12, No Iterations 1
DICPCG:  Solving for p, Initial residual = 1.057724393e-05, Final residual = 2.824820755e-13, No Iterations 1
time step continuity errors : sum local = 1.1507866e-13, global = 6.562614854e-14, cumulative = -1.40644333e-10
rho max/min : 5.383355502 0.7692116369
DICPCG:  Solving for p, Initial residual = 1.716288277e-06, Final residual = 1.285608816e-14, No Iterations 1
time step continuity errors : sum local = 5.378666265e-15, global = 8.705774841e-16, cumulative = -1.406434624e-10
rho max/min : 5.383355567 0.6781598605
DICPCG:  Solving for p, Initial residual = 1.891985206e-08, Final residual = 1.687145477e-15, No Iterations 1
time step continuity errors : sum local = 8.348058347e-16, global = -3.574820453e-16, cumulative = -1.406438199e-10
rho max/min : 5.383355567 0.6784748731
PIMPLE: iteration 3
DILUPBiCG:  Solving for Ux, Initial residual = 3.657724663e-06, Final residual = 6.051157014e-14, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 2.000624503e-06, Final residual = 6.537992318e-14, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 8.947293795e-07, Final residual = 2.190691845e-12, No Iterations 1
DICPCG:  Solving for p, Initial residual = 4.535262965e-05, Final residual = 1.564044214e-13, No Iterations 1
time step continuity errors : sum local = 6.402201821e-14, global = 4.145793719e-14, cumulative = -1.40602362e-10
rho max/min : 5.383355548 0.2
DICPCG:  Solving for p, Initial residual = 1.045788467e-06, Final residual = 8.114587543e-14, No Iterations 1
time step continuity errors : sum local = 3.330928329e-14, global = -3.216345809e-15, cumulative = -1.406055783e-10
rho max/min : 5.383355566 0.2
DICPCG:  Solving for p, Initial residual = 4.63908245e-09, Final residual = 3.206699154e-16, No Iterations 1
time step continuity errors : sum local = 2.863556535e-16, global = 3.088302968e-17, cumulative = -1.406055474e-10
PIMPLE: iteration 4
DILUPBiCG:  Solving for Ux, Initial residual = 4.132894833e-06, Final residual = 8.315058254e-16, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 2.281584771e-06, Final residual = 1.836118109e-15, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 8.269748069e-07, Final residual = 5.748967379e-13, No Iterations 1
DICPCG:  Solving for p, Initial residual = 1.118342901e-05, Final residual = 5.768516473e-14, No Iterations 1
time step continuity errors : sum local = 2.360931641e-14, global = -7.240713962e-15, cumulative = -1.406127881e-10
rho max/min : 5.383355561 0.7690964525
DICPCG:  Solving for p, Initial residual = 2.306754574e-06, Final residual = 1.128468539e-14, No Iterations 1
time step continuity errors : sum local = 4.742983271e-15, global = 1.81637703e-15, cumulative = -1.406109718e-10
rho max/min : 5.383355566 0.6453792226
DICPCG:  Solving for p, Initial residual = 2.580090896e-08, Final residual = 2.295472813e-15, No Iterations 1
time step continuity errors : sum local = 1.088034946e-15, global = -4.943138359e-16, cumulative = -1.406114661e-10
rho max/min : 5.383355566 0.6458080722
PIMPLE: not converged within 4 iterations
ExecutionTime = 722.71 s  ClockTime = 847 s
Courant Number mean: 0.005407088417 max: 0.1799486538
deltaT = 3.801022574e-09
Time = 0.000112605
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.0001704256844, Final residual = 5.454769696e-12, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.0002990829967, Final residual = 1.904069496e-13, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 6.452278284e-05, Final residual = 2.307948873e-12, No Iterations 2
[3] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #2   in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3   in "/lib/x86_64-linux-gnu/libm.so.6"
[3] #4  Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #5  Foam::pow(Foam::UList<double> const&, double const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #6  parserPatch::PatchValueExpressionParser::parse() in "/home/ehsan/OpenFOAM/ehsan-2.1.0/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
[3] #7  Foam::PatchValueExpressionDriver::parse(std::string const&) in "/home/ehsan/OpenFOAM/ehsan-2.1.0/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
[3] #8  Foam::groovyBCFvPatchField<double>::updateCoeffs() in "/home/ehsan/OpenFOAM/ehsan-2.1.0/platforms/linux64GccDPOpt/lib/libgroovyBC.so"
[3] #9   at gaussLaplacianSchemes.C:0
[3] #10  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[3] #11  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[3] #12  Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[3] #13  Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam"
[3] #14  Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam"
[3] #15
[3]  in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam"
[3] #16  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #17
[Ehsan-com:30333] *** Process received signal ***
[Ehsan-com:30333] Signal: Floating point exception (8)
[Ehsan-com:30333] Signal code:  (-6)
[Ehsan-com:30333] Failing at address: 0x3e80000767d
[Ehsan-com:30333] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36420) [0x7f768c3ca420]
[Ehsan-com:30333] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f768c3ca3a5]
[Ehsan-com:30333] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36420) [0x7f768c3ca420]
[Ehsan-com:30333] [ 3] /lib/x86_64-linux-gnu/libm.so.6(+0x60f6) [0x7f768c9510f6]
[Ehsan-com:30333] [ 4] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam3powERNS_5FieldIdEERKNS_5UListIdEERKd+0x41) [0x7f768d4645e1]
[Ehsan-com:30333] [ 5] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam3powERKNS_5UListIdEERKd+0x62) [0x7f768d466d02]
[Ehsan-com:30333] [ 6] /home/ehsan/OpenFOAM/ehsan-2.1.0/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so(_ZN11parserPatch26PatchValueExpressionParser5parseEv+0x6ff0) [0x7f767e781a30]
[Ehsan-com:30333] [ 7] /home/ehsan/OpenFOAM/ehsan-2.1.0/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so(_ZN4Foam26PatchValueExpressionDriver5parseERKSs+0x6b) [0x7f767e8129cb]
[Ehsan-com:30333] [ 8] /home/ehsan/OpenFOAM/ehsan-2.1.0/platforms/linux64GccDPOpt/lib/libgroovyBC.so(_ZN4Foam20groovyBCFvPatchFieldIdE12updateCoeffsEv+0x55) [0x7f76860c5bb5]
[Ehsan-com:30333] [ 9] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(+0xbf17e6) [0x7f768e86f7e6]
[Ehsan-com:30333] [10] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam2fv20gaussLaplacianSchemeIddE23fvmLaplacianUncorrectedERKNS_14GeometricFieldIdNS_13fvsPatchFieldENS_11surfaceMeshEEERKNS3_IdNS_12fvPatchFieldENS_7volMeshEEE+0xa6) [0x7f768e884916]
[Ehsan-com:30333] [11] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam2fv20gaussLaplacianSchemeIddE12fvmLaplacianERKNS_14GeometricFieldIdNS_13fvsPatchFieldENS_11surfaceMeshEEERKNS3_IdNS_12fvPatchFieldENS_7volMeshEEE+0x86) [0x7f768e877086]
[Ehsan-com:30333] [12] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam2fv15laplacianSchemeIddE12fvmLaplacianERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEES8_+0x67) [0x7f768e87e6e7]
[Ehsan-com:30333] [13] /opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam(_ZN4Foam3fvm9laplacianIddEENS_3tmpINS_8fvMatrixIT_EEEERKNS_14GeometricFieldIT0_NS_12fvPatchFieldENS_7volMeshEEERKNS7_IS4_S9_SA_EERKNS_4wordE+0x67) [0x442c37]
[Ehsan-com:30333] [14] /opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam(_ZN4Foam3fvm9laplacianIddEENS_3tmpINS_8fvMatrixIT_EEEERKNS_14GeometricFieldIT0_NS_12fvPatchFieldENS_7volMeshEEERKNS7_IS4_S9_SA_EE+0x93) [0x442d93]
[Ehsan-com:30333] [15] /opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam() [0x41ac6d]
[Ehsan-com:30333] [16] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f768c3b530d]
[Ehsan-com:30333] [17] /opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam() [0x41cf5d]
[Ehsan-com:30333] *** End of error message ***
mpirun noticed that process rank 3 with PID 30333 on node Ehsan-com exited on signal 8 (Floating point exception).
gnuplot> set terminal png small color
         line 0: invalid color spec, must be xRRGGBB
Killing PID 30325
 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 30325 was already dead
immortality is offline   Reply With Quote
Old   February 6, 2013, 17:47
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
We are back at the same problem, which we discussed some time ago.
Look at dump #4, #5 and #8. You are doing an illegal operation on a value using your pow-function in your groovyBC - recall Bernhard's long list of potential issues.
I guess the rest is merely pyFoam quitting because of the crash.
Good luck,
Niels
ngj is offline   Reply With Quote
Creating a new case from command line gregh OpenFOAM Pre-Processing 25 November 14, 2013 08:38
[Netgen] Netgen - Queries Batchmode & Verbose Mode shivaprasad123 OpenFOAM Meshing & Mesh Conversion 1 July 17, 2011 12:06
