TOM01 |
February 9, 2013 09:44 |
Error running Propeller Tutorial
I'm rather new to Openfoam and trying to run the propellor tutorial.
An error occurs while running the Allrun script:
in log.createBaffles
Converting faces on zone "innerCylinderSmall" into baffles.
Found 22416 faces on zone "innerCylinderSmall"
Using master patch AMI1 at index 7
Using slave patch AMI2 at index 8
Not converting faces on non-coupled patches.
Reading geometric fields
Reading volScalarField p
Reading volScalarField nut
Reading volScalarField k
Reading volScalarField epsilon
Reading volVectorField U
--> FOAM FATAL ERROR:
Problem : Patch AMI1 starts at 1756182
Current face counter at 1756183
Are patches in incremental order?
From function polyTopoChange::polyTopoChange(const polyMesh& mesh, const bool strict)
in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2459.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Foam::polyTopoChange::addMesh(Foam::polyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&) in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libdynamicMesh.so"
#3 Foam::polyTopoChange::polyTopoChange(Foam::polyMesh const&, bool) in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libdynamicMesh.so"
in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/bin/createBaffles"
#5 __libc_start_main in "/lib/libc.so.6"
at /home/abuild/rpmbuild/BUILD/glibc-2.14.1/csu/../sysdeps/i386/elf/start.S:122
In log.snappyHexMesh I find
Edge intersection testing:
Number of edges : 1756183
Number of edges to retest : 57
Number of intersected edges : 75181
Snapped mesh : cells:568602 faces:1756183 points:625033
and in system/changeDictionaryDict I see
AMI1
type cyclicAMI;
nFaces 0;
startFace 1756182;
neighbourPatch AMI2;
transform noOrdering;
surface
AMI2
type cyclicAMI;
nFaces 0;
startFace 1756182;
neighbourPatch AMI1;
surface
