[Sponsors] | |||||
ehsan
Rep Power: 6 ![]() |
I have changed fvSchemes as this:
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) cellLimited leastSquares 1.0;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phid,p) Gauss upwind;
div(phi,K) Gauss upwind;
div(phi,h) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(phi,omega) Gauss upwind;
div((rho*R)) Gauss linear;
div(R) Gauss linear;
div(U) Gauss linear;
div((muEff*dev2(T(grad(U))))) Gauss linear;
div(tauMC) Gauss linear;
laplacianSchemes
default Gauss filteredLinear2 corrected;//limited .5
/*laplacian(muEff,U) Gauss linear corrected;
laplacian(mut,U) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DomegaEff,omega) Gauss linear corrected;
laplacian((rho*(1|A(U))),p) Gauss linear corrected;
laplacian(alphaEff,h) Gauss linear corrected;
laplacian(k,T) Gauss linear corrected;
laplacian(alpha,e) Gauss linear corrected;
laplacian(alphaEff,e) Gauss linear corrected;*/
interpolationSchemes
default linear;
snGradSchemes
default corrected;//limited .5
fluxRequired
default no;
p ;
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : rhoPimpleFoam Date : Feb 09 2013 Time : 21:47:49 Host : "Ehsan-com" PID : 30304 Case : /home/ehsan/Desktop/WR_Pimple_filling nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: max iterations = 4 field "(U|k|omega)" : relTol 0, tolerance 1e-11 Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type laminar Creating field dpdt Creating field kinetic energy K Starting time loop Courant Number mean: 4.292084727e-06 max: 0.001188434481 deltaT = 6.711409396e-09 Time = 6.71141e-09 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 --> FOAM FATAL ERROR: request for surfaceScalarField corrected from objectRegistry region0 failed available objects of type surfaceScalarField are 3 ( weights phi deltaCoeffs ) From function objectRegistry::lookupObject<Type>(const word&) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 131. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 at filteredLinear2.C:0 #3 Foam::surfaceInterpolationScheme<double>::addMeshConstructorToTable<Foam::LimitedScheme<double, Foam::filteredLinear2Limiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr> >::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #4 Foam::surfaceInterpolationScheme<double>::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" #5 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::addIstreamConstructorToTable<Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double> >::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #6 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so" #7 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so" #8 Foam::compressible::laminar::divDevRhoReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so" #9 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" Aborted Killing PID 30302 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 30302 was already dead Getting LinuxMem: [Errno 2] No such file or directory: '/proc/30302/status' ehsan@Ehsan-com:~/Desktop/WR_Pimple_filling$ pyFoamPlotRunner.py --hardcopy --with-courant --no-pickled-file rhoPimpleFoam |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM | 284 | April 8, 2013 09:19 |
| c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
| Saving ParaFoam views and case | sail | OpenFOAM Paraview & paraFoam | 9 | November 25, 2011 15:46 |
| DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
| user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
