February 9, 2013, 14:38 |
how to use bounded in fvSchemes?
Ehsan
Rep Power: 26 |
when i use boundes scheme like this:
laplacianSchemes { default Gauss linear bounded;//limited .5 /*laplacian(muEff,U) Gauss linear corrected; laplacian(mut,U) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; laplacian(DomegaEff,omega) Gauss linear corrected; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(alphaEff,h) Gauss linear corrected; laplacian(k,T) Gauss linear corrected; laplacian(alpha,e) Gauss linear corrected; laplacian(alphaEff,e) Gauss linear corrected;*/ } interpolationSchemes { default linear; } snGradSchemes { default bounded;//limited .5 } Code:
Create time Create mesh for time = 6e-05 PIMPLE: max iterations = 4 field "(U|k|omega)" : relTol 0, tolerance 1e-11 Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type laminar Creating field dpdt Creating field kinetic energy K Starting time loop Courant Number mean: 0.03531419379 max: 0.2648126303 deltaT = 2e-07 Time = 6.02e-05 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 --> FOAM FATAL IO ERROR: Unknown discretisation scheme bounded Valid schemes are : 3 ( corrected limited uncorrected ) file: /home/ehsan/Desktop/WR_Pimple_filling/system/fvSchemes::laplacianSchemes::default at line 50. From function snGradScheme<Type>::New(const fvMesh&, Istream&) in file lnInclude/snGradScheme.C at line 82. FOAM exiting ehsan@Ehsan-com:~/Desktop/WR_Pimple_filling$ |
April 2, 2013, 06:14 |
Ehsan
Rep Power: 26 |
i saw bounded in user guide.doesn't it work?is it incorrect?
February 15, 2016, 19:19 |
Jack
Rep Power: 13 |
A few examples:
div(phi,U) bounded Gauss linearUpwindV grad(U); div(phi,k) bounded Gauss upwind; |
Bounded cuttingPlane? | CedricVH | OpenFOAM | 2 | August 5, 2011 05:10 |
fvschemes and fvsolutions in MRFSimpleFoam | renyun0511 | OpenFOAM Running, Solving & CFD | 23 | August 3, 2011 04:07 |
about bounded alpha equation for bubbleFoam and twoPhaseEulerFoam | kaifu | OpenFOAM | 2 | May 6, 2011 05:33 |
strictly bounded scalars | Mo-ITB | OpenFOAM | 3 | July 19, 2010 17:18 |
Higher-order bounded convection schemes for pure advection with discontinuity | Anthony | Main CFD Forum | 3 | June 13, 1999 02:36 |
