interFoam algorithm
Old   February 18, 2013, 05:46
Default interFoam algorithm
Pierre HORGUE
Pedro24 is on a distinguished road
Hi ,
For each time step, I found that the order of the computations is a little bit strange.
1) It computes the new surface force term using the alpha field at the time "n"
       twoPhaseProperties.correct();
2) Compute the alpha field "n+1" using the velocity field U at the time "n"
        #include "alphaEqnSubCycle.H"
3) Compute the pressure-velocity field at the time "n+1" using the surface term force at the time "n"
        // --- Pressure-velocity PIMPLE corrector loop
        while (pimple.loop())
            #include "UEqn.H"
            // --- Pressure corrector loop
            while (pimple.correct())
                #include "pEqn.H"
            if (pimple.turbCorr())
                turbulence->correct();
Why don't we inverse the step 1 and 2. It will allows to use the surface term force at the time "n+1" in the navier-stokes equations ?
It seems more logical to update the surface force term (step 1) just after computing the new alpha field. In my mind, the algorithm should be :
1) update properties time "n"
2) compute implicitly velocity-pressure field "n+1"
3) compute alpha field "n+1" using the velocity-pressure previously computed
Am I wrong ?
Thank You,
Pierre
Pedro24 is offline   Reply With Quote
Old   February 19, 2013, 06:20
Pierre HORGUE
I confirm what I said before, this is an error in the "interFoam" solver (and the derivated solvers).
In the H. Rusche thesis, page 162, we can see the following solution procedure :
steps 1-4 : refer to the moving frame
step 5 : transport "alpha1"
step 6 : update properties (smooth gamma => curvature computation => surface force term)
step 7 and 8 : PISO-loop to compute pressure-velocity fields.
Maybe this error should be reported to the OpenFOAM Foundation to correct it for the following versions.
Pierre
Old   February 19, 2013, 07:51
akidess's Avatar
Anton Kidess
How are step 5-8 different than what is already implemented?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   February 19, 2013, 07:58
Pierre HORGUE
In the current version of "interFoam", the step 6 is computed before the step 5.
First it computes the surface force term :
and then it computes the new alpha1 field :
So, the surface force term used in the PISO loop is computed using the old-time alpha field, which is different from the usual solution procedure.
Old   February 19, 2013, 09:50
akidess's Avatar
Anton Kidess
The interface curvature for the surface force term is calculated by calling interface.correct() after the alphaEqnSubCycle.
Old   February 19, 2013, 10:03
Pierre HORGUE
Ok, I had inverted the "correct" function of twoPhaseMixture for the viscosity with the "correct" function of interfaceProperties for the curvature.
Thank you for your reply
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
Does PISO algorithm work with interfoam in openFOAM 2.1.0? Krishna Sandeep OpenFOAM Running, Solving & CFD 3 June 14, 2012 01:32
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
