Home > Forums > OpenFOAM Running, Solving & CFD
difference between 2.1.0 and 2.1.1 run.?
Old   February 13, 2013, 07:39
Default difference between 2.1.0 and 2.1.1 run.?
immortality's Avatar
Ehsan
immortality is on a distinguished road
although the run in openfoam 2.1.0 starts and after 500 iterations diverges.in 2.1.1 it doesn't start at all and shows an error:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : sonicFoam
Date   : Feb 13 2013
Time   : 15:04:08
Host   : "Ehsan-com"
PID    : 7412
Case   : /home/ehsan/Desktop/My_WR_sonicFoam
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>>
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::ePsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4  Foam::ePsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::ePsiThermo(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5  Foam::basicPsiThermo::addfvMeshConstructorToTable<Foam::ePsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6  Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/sonicFoam"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception
Killing PID 7410
 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 7410 was already dead
Getting LinuxMem: [Errno 2] No such file or directory: '/proc/7410/status'
ehsan@Ehsan-com:~/Desktop/My_WR_sonicFoam$
my groovyBC is latest version.0.2.1 as funkySetFields verifies too at both openfoam versions.
immortality is offline   Reply With Quote
Old   February 14, 2013, 17:05
Ehsan
any opinion or thought?
Old   February 26, 2013, 19:17
Ehsan
has had someone similar experience or any idea related?
Old   February 27, 2013, 11:44
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Hi Ehsan,
I'll quote myself from another thread on a nearly identical topic:
Originally Posted by wyldckat View Post
Not much information you're giving us. All that can be seen from this is that:
This implies that something is improperly defined, such as temperature set at 0 Kelvin, or pressure defined at 0 Pa... or something else.
Additionally, since you're comparing 2.1.0 with 2.1.1, then something was either fixed or broken in the mean time.
And without having access to at least a simple test case, then it only makes it harder to figure out what changed.
Best regards,
Bruno
Thread Tools
Trackbacks are On
OpenFOAM 2.1.1 installation on openSUSE 12.2 32 bit saturn_53 OpenFOAM Installation 13 February 1, 2015 05:17
Add temperature to icoFoam in OpenFOAM 2.1.1 magnounibo OpenFOAM Programming & Development 11 April 14, 2013 13:20
Gettings started after installing OpenFOAM 2.1.1 in Ubuntu 12.10 yoddha24 OpenFOAM 7 November 22, 2012 12:46
New USer of OpenFOAM: How to run tutorials novice OpenFOAM 3 September 26, 2012 09:03
OpenFOAM Foundation Releases OpenFOAMŪ Version 2.1.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 May 31, 2012 09:07
