-   -   ePsiThermo<pureMixture<constTransport error (http://www.cfd-online.com/Forums/openfoam-solving/113144-epsithermo-puremixture-consttransport-error.html)
immortality February 13, 2013 09:50
could someone explain about this error in 2.1.1 version?
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  2.1.1                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
Build  : 2.1.1-221db2718bbb
Exec  : sonicFoam
Date  : Feb 13 2013
Time  : 16:48:14
Host  : "Ehsan-com"
PID    : 10338
Case  : /home/ehsan/Desktop/My_WR_sonicFoam
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4  Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::ePsiThermo(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5  Foam::basicPsiThermo::addfvMeshConstructorToTable<Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6  Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/sonicFoam"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception
immortality February 14, 2013 16:10
any comments?
immortality February 16, 2013 10:03
may this error related to groovyBC i use?
wyldckat February 16, 2013 12:39
Hi Ehsan,
It's a floating point error ("sigFpe"), which either means a division by zero or infinite or something similar. For some more information: http://en.wikipedia.org/wiki/SIGFPE#SIGFPE
Said error occurred at:
Without seeing the real numbers on the file you are using, it's (nearly) impossible to guess which value is invalid...
Best regards,
Bruno
