How to define a surface source term in the energy equation across a flow |
June 30, 2016, 08:52 |
Jeff
Rep Power: 9 |
Hi foamers
I am facing the following problem: a stream of air in a pipe passes through an electrically heated gauze. I need to estimate air température downstream the gauze and gauze peak temperature. (pressure drop can be initially neglected). I need to add a "heating" source term to the energy equation for that purpose.(also the heating power will be function of temperature so I will use a swak4foam expression). To the best of my knowledge (please correct me if I am wrong), I can use fvOption only if I model the heat source as a volume source in a layer around the gauze. This is a problem in my context for the following reasons: 1 If I choose the thickness of this layer as the thickness of the gauze it creates ridiculously small and umpractical mesh. 2- if I choose larger mesh I underestimate the peak temperature which is not good for practical reason My questions: Is there an existing way ( ideally materialized through an example /tutorial) to define a surface heat source on a patch across the flow? Any recommandation how to tackle this configuration? Thanks a lot JF |
Conjugate Heat Transfer in Two-Phase Flow | Parisa_Khiabani | OpenFOAM Programming & Development | 12 | June 3, 2019 04:07 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
