Problem with tempFoam setting system/fvSolution
Old   February 15, 2013, 11:14
Default Problem with tempFoam setting system/fvSolution
Daniele Obiso
danobis is on a distinguished road
i'm new with OpenFOAM, and i'm trying to learn using it thanks to some tutorials.
I'm studyng a HVAC problem with a thermal transient.
I run the case and it seems to go well, but before endTime i get a crash with this error:
#0 Foam::error:rintStack(Foam::Ostream&)--------------------------------------------------------------------------
An MPI process has executed an operation involving a call to the
"fork()" system call to create a child process. Open MPI is currently
operating in a condition that could result in memory corruption or
other system errors; your MPI job may hang, crash, or produce silent
data corruption. The use of fork() (or system() or other calls that
create child processes) is strongly discouraged.
I think the problem is the solver used for temperature in system/fvSolution, because i was not sure about setting it. I used both GaussSeidel and PBiCG, and it's not working.
Any tip about this problem?
Best regards,
Daniele
danobis is offline   Reply With Quote
Problem setting C_MU_T with DEFINE_ADJUST Andy FLUENT 3 June 22, 2018 02:53
Problem in setting porosity region for rhoPorousSimpleFoam run_cfd OpenFOAM Pre-Processing 1 May 31, 2011 09:02
Problem setting AV Marko CFX 0 March 18, 2005 08:06
Problem setting C_MU_T with DEFINE_ADJUST sarah_ron FLUENT 1 February 24, 2005 12:11
Help setting up combustor problem Tom FLUENT 0 February 5, 2005 01:20
