Question on DecomposePar
Old   February 19, 2013, 10:18
Default Question on DecomposePar
nore5 is on a distinguished road
I am trying to run calculations on parallel 8simple method) but each time I use decomposedPar I get that kind of error after it assigns cells, patches and .. to each processor. I can't figure out where it comes from.
--> FOAM FATAL IO ERROR:
size 2520 is not equal to the given value of 5538
file: /home/noba/OpenFOAM/noba-2.1.1/run/cube2/0/U::boundaryField::inlet from line 36 to line 5097.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/noba/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
Thank you in advance for your help.
Nore
nore5 is offline   Reply With Quote
Old   February 19, 2013, 14:40
Default DecomposePar question
Nick Dale
RocketMan1691 is on a distinguished road
I have not had the problem with decomposePar but something similar happens when you mess with the run sequence for blockMesh and snappyH. Running the programmes in the wrong sequence can leave old files in the directories. The old files have the wrong cell count which is flagged by the next programme.
Not sure if that is what is happing here, but maybe it is something similar.
RocketMan1691 is offline   Reply With Quote
Old   February 19, 2013, 15:33
Thanks for the reply. So you advice me to remove all the files and keep the ones needed for running the simulation?
I will tru and let you know....
Thanks again
Old   February 19, 2013, 15:58
Nick Dale
The give away is creation time. Old files will have a time that is out of sequence with the others in the directory.
Old   February 19, 2013, 16:20
It worked for me. Thanks. Still i did not understand your last message please abut creation time, Could you explain please?
Old   February 19, 2013, 16:45
Nick Dale
When I have had the problem, it happened because I had to rerun a programme I had already run. Each programme writes its output at more or less the same time. So the creation times are similar. In some parts of the processing chain, later files overwrite earlier ones. If run in the right order, all the relevant files are over written, again at more or less the same time. When the earlier programme is rerun, some of the files have been overwritten with the wrong data and the inevitably wrong cell count. The re-run programme complains.
To de-bug it, just look for an creation time that does not match its neighbours. It may be earlier or later but it will standout.
Hope that makes sense.
Question about blockMesh and decomposePar ywang OpenFOAM 2 June 18, 2011 13:28
Question about decomposePar RDanks OpenFOAM Pre-Processing 2 May 20, 2011 09:24
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
transientSimpleDyMFoam, mapFields and decomposePar pad OpenFOAM Running, Solving & CFD 0 December 3, 2010 05:22
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
