Vector operations on Cell Zones
Old   October 31, 2011, 18:35
Default Vector operations on Cell Zones
Ganesh Vijayakumar
ganeshv is on a distinguished road
Can I get standard vector operations done on certain cell zones alone.. For e.g fvm::laplacian(U) or fvc::grad(U)?
ganeshv is offline   Reply With Quote
Old   October 31, 2011, 22:33
Sandeep Menon
deepsterblue will become famous soon enough
Take a look at fvMeshSubset. This allows you to define an fvMesh on a set of cells (where exposed internal faces are added to a "default" patch).
Once you have this defined, you can define GeometricFields (like volVectorFields such as velocity - U) using this mesh subset, and subsequently, vector calculus operators as well.
Boundary conditions, etc will all be handled automatically.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   November 1, 2011, 00:11
Default Example?
Ganesh Vijayakumar
hi Sandeep,
Could you point me to an example where fvMeshSubset is used inside a code? That would be extremely helpful.
Old   November 1, 2011, 07:41
Sandeep Menon
I can't seem to find any examples, but you can accumulate a set of cells in a labelHashSet, and use the fvMeshSubset::setCellSubset member function to construct your mesh. From then on, field creation, etc is the same as fvMesh, but you would substitute the fvMeshSubset::subMesh() member function instead of a regular mesh.
Sandeep Menon
Old   February 19, 2013, 11:39
Default Urgent help on fvMeshSubset
Fabian Wein
Fabian_W is on a distinguished road
I need to do the same and came to the same idea. My problem is, that setCellSubset fails.
Here my example code:
labelHashSet sub;
for(int i = 0; i < mesh.C().internalField().size(); i++)
const vector& v = mesh.C().internalField()[i];
if(v.x() > 8.75-1e-5 && v.x() < 13.75+1e-5 && v.y() > 1.25-1e-5 && v.y() < 6.25+1e-5 && v.z() > 0.5595-1e-5 && v.z() < 1.5605+1e-5)
sub.insert(i);
fvMeshSubset sm(mesh);
sm.setCellSubset(sub);
I have the following problem:
Number of cells in new mesh: 18
Number of faces in new mesh: 75
Number of points in new mesh: 48
--> FOAM FATAL ERROR:
Cannot find face 281 in any of the patches
3
sideWalls
topWalls
inlet
It seems your patches are not consistent with the mesh : internalFaces:278 total number of faces:442
From function label polyBoundaryMesh::whichPatch(const label faceIndex) const
in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 541.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam:olyBoundaryMesh::whichPatch(int) const in "/opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 Foam::fvMeshSubset::setCellSubset(Foam::HashSet<in t, Foam::Hash<int> > const&, int) in "/opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
Any help is very much appreciated!!
Thanks,
Fabian
Fabian_W is offline   Reply With Quote
Old   February 21, 2013, 08:24
Default Solved
Fabian Wein
my problem was, that external faces where not assigned to a label and the internal mesh intersects these external faces.
cellzone
[Other] how to extract cell zones by cgnsToFoam Ohbuchi OpenFOAM Meshing & Mesh Conversion 0 July 22, 2010 04:19
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
Tracking/Modifying Cell Zones Greg Perkins FLUENT 1 November 6, 2000 23:35
