Home > Forums > OpenFOAM Running, Solving & CFD
Mapping fields between different programs
Old   February 25, 2013, 05:04
Post Mapping fields between different programs
Simone
batta31 is on a distinguished road
Hi guys, I have this question:
I have to import the velocity and pressure field from another program (STAR CCM+), and I need to use these fields as inlet condition on my case, which has the same geometry (in terms of body and patches) of the case run in STAR, but a different volume mesh (which is made with ANSA). Is there a way to interpolate those fields in order to use them with OpenFOAM?
I heard about the utility mapFields, to be used with different solvers inside OF, but I don't know if it can be used also between different programs.
Thank you for your replies!
Simone
batta31 is offline   Reply With Quote
Old   February 25, 2013, 09:52
Sandeep Menon
deepsterblue will become famous soon enough
You may want to take a look at MPCCI - not sure how relevant it is, though
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   February 25, 2013, 18:56
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
I'll quote myself from the other day, because it seems to fit quite nicely:
Originally Posted by wyldckat View Post
I believe what you're looking for is exemplified in the tutorial "incompressible/simpleFoam/pitzDailyExptInlet", in particular inside the folder "constant/boundaryData/inlet/".
There isn't much more I know of this tutorial, so I can only suggest you study it and do tell us if you have problems with it!
In essence: you need to export the inlet data you want to use, to CSV or something else, on Star-CCM+. Then refurbish the CSV data to the format in the example I quoted and there you have it!
Best regards,
Bruno
Old   February 26, 2013, 03:41
Simone
Thanks for your answer Bruno, it's a starting point for sure. But I have (maybe) a little problem, which is linked to the fact that also the inlet patch from which I extract the data in STAR has a different grid (and so different nodes) with respect to the one that will be used in ANSA. The file "points" in your example has generic coordinates or maybe those points are exactly the nodes of the inlet? This could be the answer..
Old   February 26, 2013, 05:16
Bruno Santos
You could probe/sample/interpolate the points on the original mesh...
Thread Tools
Trackbacks are On
fvMeshSubset and labelHashSet: mapping fields between the meshes Arnoldinho OpenFOAM Programming & Development 1 February 19, 2012 10:05
moving domain, interFoam and mapping fields pablodecastillo OpenFOAM Programming & Development 1 April 23, 2011 14:45
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
MultiDirRefinement class Bug on mapping fields zurdo OpenFOAM Bugs 12 December 17, 2007 05:54
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
